0w20 to 10w30 oil 2019 V6 auto
Discussion in '3rd Gen. Tacomas (2016-2023)' started by amocat91, Apr 29, 2025.
  1. May 8, 2025 at 1:04 PM
    SimonSaysBoo
    SimonSaysBoo Member
    Tacoma 2.7
    Induction, Ceramics, Wrangler Kevlar, Shell VP
    Used to work in fuels and oils etc etc...
    Firstly - When new (up to 50k) I would always stick to the grade on the oil cap.
    Secondly - The car companies are obsessed with manipulating MPG figures and 0w20, 0w16 etc does that. There is no secret that these lighter grades give increased mileage but at an ever, ever so slight wear cost.
    Third - The new engines require a harder working, higher quality oil, that often leans towards a lower viscosity, for VVT and VVI etc
    Fourth - Consider your operating climate / conditions.
    The Standard to meet warranty in the Tacoma 2.7 4 is ILSAC GF-6A. As well as Mobil 1 0w20, that is found in the Mobil 1 0w30 Advanced Fuel Economy for example... (why use any other brand - just saying).
    ILSAC GF-6A is NOT found in the Mobil 1 0w30 ESP also Mobil 1. High quality oil specifications will cross over between grades.
    Also the owners manual uses the wording 'recommends' not 'must do'
    In hot environments and high speed and high workload I would recommend going up a viscosity level. 0w30 meets those requirements for warranty and added protection in heat and high workload.
    0w30 is generally considered to be used where ambient air temperature is 36c / 97f. So if you live in these climates then why not give yourself the protection ?
    In Summary Mobil 1 0w20 and 0w30 Advanced Fuel Economy (Any probably other brands you can research) have the required ILSAC GF-6A which is the only engine oil specification requirement mentioned in the Toyota manual.
    Therefore being May in the South, currently using Mobil 1 0w30 AFE in my Tacoma 2.7 , If I lived further North (and in Winter) I would put 0w20 in.
    Hope that helps.
  2. May 8, 2025 at 1:18 PM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Going to a 0W30 is fine but its not going to change anything for noise. The noises from this engine are not valvetrain but are the injectors and the high pressure fuel pump. Neither are affected by oil weights. I would stick with 0W-x oils as the cold flow is still a higher viscosity than any 10W-30 or 15W-40 oil when hot but is obviously thinner then the 10 and 15W when cold. This thinner when cold is good as others have mentioned to get oil to VVT, etc quicker on startup.
    In short, no reason to switch oils as 1. it wont impact noise its just how modern engines are, and 2. there is zero evidence that 0W-20 is causing any longevity issues with these engines. Even used oil analysis (the actual proof) confirms this.
    There are not L87's :rofl:
    BUZZCUT and Koolbreeze7 like this.
  3. May 8, 2025 at 3:57 PM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    There is a spring loaded pin that locks the gear to the cam until oil pressure builds to unlock...it's the lock pin that prevents the rattle.
  4. May 8, 2025 at 4:11 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There are definitely lifter noises posted here from time to time and they are for sure different from the HPFP and direct injectors/cleaning cycle noises. I have yet to hear any lifter tapping since switching to 10W-40, but I suppose summer will be the real test because that’s the time of year I hear it, if I do. I hope I’m out of this truck by then.
  5. May 9, 2025 at 9:25 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I’m gonna stick with factory spec on my 2019.
