1/2" wheel spacer? Any where I can find one?
Discussion in 'Wheels & Tires' started by wing103, Sep 2, 2011.
  1. Sep 2, 2011 at 1:46 PM
    wing103
    wing103 [OP] Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Hi
    Can any one help me out here, I am looking for 1/2" wheel spacer for a 2009 tacoma. 6lugs.
    Any idea???:confused:
  2. Sep 2, 2011 at 1:51 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    1/2" is pretty thin. You're not going to find proper wheel spacers until you bump up to around 1.25" or 1.5" because there's not enough room to sink the lug nuts.
    By "proper" spacers I mean the type that get bolted to your stock wheel lugs and have their own lugs installed that your wheels then attach to.
    The other type is just a thin metal ring with holes that a) allows slop when mounting your wheel causing balancing issues, and b) reduces the amount of threads the lug nuts can grip, increasing the chance that a lug nut could back off or strip threads causing you to lose a wheel.
  3. Sep 2, 2011 at 2:35 PM
    wing103
    Boston
    The reason I ask is after I install a set of after market wheels and tires, the passanger side stick out like 1/2" more than driver side.
    Than I think about may be i can add a 1/2" spacer to make it even.
    Like you said, If I add two 1.25 on driver side, and add 1.75 on one side, will this work?
  4. Sep 6, 2011 at 8:04 AM
    mjp2
    NJ
    Sorry for the delayed response. I try not to be online on the weekends. :cool:
    If you see a discrepancy in the amount the tires stick out, you'd be better off locating the cause rather than trying to compensate with spacers. There really shouldn't be a difference drastic enough to be noticeable.
    Got any pics of your setup showing the difference between the two sides? Also include shots of your alignment cams. It's possible that your last alignment pulled the wheel in on one side and shoved it outward on the other.
