1.25” Wheel Spacer Rub?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrshaw91450, Aug 22, 2021.
  1. Aug 22, 2021 at 9:14 AM
    jrshaw91450
    jrshaw91450 [OP] Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    Im adding some 1.25” wheel spacers to my taco which has about 2” of lift from some Bilstein 5100s and 265/75/16 Wildpeaks. I should be clear of any rubbing right?
  2. Aug 22, 2021 at 9:20 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    OP you have stock off-road wheels? If so you will be fine.
  3. Aug 22, 2021 at 10:08 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    you will be fine i had a 3in front and 2in rear lift kit and never rubbed on 285/75/16
    71tattooguy likes this.
  4. Aug 22, 2021 at 11:26 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    The 265 will rub without spacers. You’ll Be fine with them
  5. Aug 22, 2021 at 3:24 PM
    jrshaw91450
    Maui
    Yes, like the stock OR Rims look. Currently have 265/75/16 but feel they need a bit of offset to even up with wheel well & look better. Would like to go one more tire size up, but the heavy weight of bigger tires kills this engine. Hopefully the spacers give a better look.
    71tattooguy[QUOTED] likes this.
  6. Aug 22, 2021 at 3:30 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Spacers make rubbing issues on the firewall.
  7. Aug 23, 2021 at 9:32 PM
    brtnstrns
    brtnstrns Well-Known Member
    Seattle
    2020 Voodoo Blue TRDOR DCSB
    I have 265/70/17 tires on 4Runner TRDOR wheels which have -10mm more of negative offset than the Tacoma TRDOR wheels (I also think they're wider) and run 1.25" spacers with about a 1.5 to 2 inch lift and have no rubbing at all.
    I think you'll be fine and not have any rubbing problems and it'll look much nicer.
    jrshaw91450[OP] likes this.
