1.25 inch spacers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bdunna, Nov 19, 2019.
  1. Nov 19, 2019 at 3:48 AM
    bdunna
    bdunna [OP] Well-Known Member
    2005 tundra access cab
    Looking to see if anyone has some pics and suggestions on spacers. Currently have 265/70/17 BFG K02s (1 size up) on stock suspension, and stock mud flaps. Looking for a little more stance. Have done some research but not seeing much. Assuming most go with new wheels.
    Main concern: rubbing. If there is rubbing i'm out and waiting till paid off. Then will get wheels and tires (probably skinny's). I live in a salt state, so don't really want to get aftermarket wheels. Factory wheels just seem to deal with the salt better over the years of abuse.
    Thanks in advance
  2. Nov 19, 2019 at 2:01 PM
    bdunna
    Spacers
  3. Nov 19, 2019 at 2:05 PM
    KickAss
    KickAss Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    spidertrax, they are hubcentric for the tacoma which is essential. It's going to push the wheel/tire out obviously, but that may make it rub the mudflaps or wheel well, even if not rubbing now. I don't have pics, but that's the basics.
    Good luck
  4. Nov 20, 2019 at 1:36 AM
    Kings
    Kings Well-Known Member
    Cole
    Ontario, Canada
    2018 Tacoma TRD OR MGM
    17x8.5 SCS Ray 10s, 265/70/17 BFGoodrich KO2s, 2.5" ADS Ext. Travel coil-overs and shocks with compression adjusters, ICON tubular Delta Joint UCAs, Extended brake lines front and rear, OME medium duty Dakar leaf pack, Locked Offroad hydraulic rear bump stops
    You'll have to take the mud flaps off for sure but other than that you should be fine. You'll get a little more poke but not too much. I didn't take pictures but when I put my -10 rims on I just had to take the mud flaps off. Stock suspension and 265-70-17 KO2s
    PS. I live in Southern Ontario where the salt is pretty bad in the winter and I use my Ray 10s year round. I coat them with jet seal and wheel guard from chemical guys before it snows and just use the coin was every two weeks to get the salt off the underbody and wheels. It works really well, just another option for you to consider. Cheers
  5. Nov 20, 2019 at 10:35 AM
    robie_0n3
    robie_0n3 Well-Known Member
    David
    Scott AFB, IL
    2018 Tacoma TRD Off Road
