1/4” spacer with coil overs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Phil4200, Jul 6, 2021.
  1. Jul 6, 2021 at 11:33 AM
    Phil4200
    Phil4200 [OP] Well-Known Member
    2018 Tacoma SR5 DC 4x4
    3.5 RC Vertex coil overs, SPC uppers, rear blocks\RC V2 monotubes CVC tune 3.0 mbrp exhaust
    Can I get some advice on adding a 1/4 spacer to each side of my coil overs. I have the Vertex 3.5 by RC and I would like another half inch of front lift, they barely yielded 3” out of the box. Truck still has a slight rake would like it level without pre loading my springs. Has anyone done this? I’m not a real hard off reader either. Oh and my CV boots are not touching so I know they will probably after. Thanks
  2. Jul 6, 2021 at 11:36 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Don't do it unless you have stock in a CV/axle company.
  3. Jul 6, 2021 at 11:38 AM
    eon_blue
    Azusa, CA
    Once the CV boot fins touch, they will rub apart in no time and you'll be replacing and/or rebooting CV axles constantly.
    That being said, people put small spacers on top of coilovers all the time to compensate for lean in one direction. Usually not 1/4" though
    Grossomotto and Phil4200[OP] like this.
  4. Jul 6, 2021 at 11:38 AM
    Phil4200
    So do you suggest just adjusting the spring preload to get a little more
  5. Jul 6, 2021 at 11:39 AM
    eon_blue
    Azusa, CA
    That'll do the same thing, higher you go the steeper the CV angles will get. Unless you do a body lift or drop bracket lift.
    This is why 3" is usually the max anyone goes (with 4wd), on IFS trucks anyway.
    Grossomotto likes this.
  6. Jul 6, 2021 at 11:40 AM
    Phil4200
    Ok, kinda what I figured, thanks
  7. Jul 6, 2021 at 11:41 AM
    TRD-ED
    Lenoir NC.
    You said you're at 3" of lift now. That's maxed out on the CV angle. (probably)
    Adding more lift/angle will just add fuel to the fire.
    Phil4200[QUOTED][OP] likes this.
  8. Jul 6, 2021 at 11:43 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    CV angle aside, when you get higher up in lift, you're taking away your available droop (dropout). So you'll be topping out (hitting full extension) over every little bump and it'll ride like ass.
    *this applies to standard lifts, not drop brackets, long travel, etc*
    Grossomotto, 71tattooguy and TRD-ED like this.
