1/4” taco lean spacer vs. leveling kit.
Discussion in 'Suspension' started by Cardsallday13, Jun 29, 2018.
  1. Jun 29, 2018 at 5:25 AM
    Cardsallday13
    Cardsallday13 [OP] Well-Known Member
    2017 DCSB TRD Sport 4x4
    Question. Haven't been able to find anything in the search. I went to the local 4 wheeler shop to ask about having the .25 spacer installed to combat the taco lean. The guy told me what I really want is this 2.5" leveling kit.
    So what is the difference? Is the leveling kit for left to right it front to back lean?
  2. Jun 29, 2018 at 5:33 AM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Lean spacer is from right to left (passenger to driver) and the leveling kit is from front to back (to remove any rake). If you get a leveling kit you should also get a lean spacer.
    DrFunker and shr133 like this.
  3. Jun 29, 2018 at 5:34 AM
    Cardsallday13
    Thanks. Wasnt sure When he was trying to sell me. Like the look front to back.
    Thanks
  4. Jun 30, 2018 at 8:10 PM
    Oldgrumpy2810
    Oldgrumpy2810 Member
    Tyger Boards, USB Ports inside... more to come
    I am going to chime in on this.
    I have an appointment with my local dealership on Monday and they claim there is some Toyota fix for it.
    As I am fighting the left-right lean as well...
    Is there a TSB or in-house solution other than getting the spacer installed?
    Thanks!
  5. Jul 1, 2018 at 5:23 AM
    Cardsallday13
    Dunno. Spacer is all I have heard about. Let us know what the dealer tells you
  6. Jul 2, 2018 at 6:38 AM
    Cardsallday13
    Any update?
  7. Jul 2, 2018 at 7:19 AM
    Oldgrumpy2810
    I just dropped the truck off.
    The acknowledged the issue and will look into it.
  8. Jul 2, 2018 at 11:52 AM
    Cardsallday13
    i almost bet that they will tell you they are all like that and that it is in spec.
    i am having Big-O near me install the 1/4" spacer as we speak. Quoted me $100 labor.
    Clearwater Bill likes this.
  9. Jul 3, 2018 at 11:46 AM
    Cardsallday13
    Had the spacer added. With full tank reduces the lean from 5/8" to about 1/8-3/16”
  10. Jul 4, 2018 at 1:22 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I use a 1/4" spacer...
  11. Jul 4, 2018 at 1:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    Don't go back there.
    Chucklehead. Either ignorant or dishonest.
  12. Jul 4, 2018 at 2:31 PM
    Cardsallday13
    Any word from the dealer?
  13. Jul 17, 2018 at 7:00 PM
    Oldgrumpy2810
    Hi guys!
    Well, the dealer is having this issue elevated to Toyota.
    The lean is now at 1.25in on the left aft side.
    We measured other Tacomas on the lot and with the tank full (dealer standard) there was either no lean or minimal lean (.5in).
    I took the truch back and we are waiting on Toyota to respond.
    Problems keep coming however. Now the truck studders and shakes badly between 1500-2000 rpm. Plugs were replaced, fuel/water test was negative.
    Seems I have a bit more work to get done...
    Crazy.
  14. Jul 17, 2018 at 7:02 PM
    Cardsallday13
    Hmm. Pretty different than what I was seeing
  15. Jul 18, 2018 at 8:25 AM
    Oldgrumpy2810
    I am sorry. What were you seeing?
    This does not mean they will fix it. I am fully aware of the likeliness that I will be told that this is what it is. I can buy a leveling kit and have it installed by Toyota and what not...
    Let's see what happens and what they come around with...
  16. Jul 18, 2018 at 8:29 AM
    Cardsallday13
    Maybe lean for me was like 5/8"
  17. Jul 18, 2018 at 8:37 AM
    Oldgrumpy2810
    Oh, I see.
    Perhaps this explains my concern with the whole situation.
    Now, to drive the conversation forward:
    I do not want to lift the truck, but what leveling kit can you guys recommend. I will not be putting on different tires. I would be ok with a minimal lift as my priority is the leveling.
    Any advice?
  18. Jul 18, 2018 at 8:41 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    I'm not sure what you mean by not wanting to lift the truck but wanting to level it. You have to level it by lifting the front end. A "leveling kit" is typically a spacer that goes on top of the coilover, which I personally would not put on my truck. This will lift the front end and will make the truck sit level.
    You can see the suspension forum for this. These topics have been discussed at length.
  19. Jul 18, 2018 at 8:43 AM
    Oldgrumpy2810
