1/4 mile
Discussion in 'X-Runners' started by AUDITECH, Sep 6, 2008.
  1. Feb 16, 2009 at 6:09 PM
    #41
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    cheater.
  2. Feb 17, 2009 at 6:38 AM
    #42
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Ha.. coming from the neg DA master...
  3. Feb 17, 2009 at 2:06 PM
    #43
    AUDITECH
    AUDITECH [OP] Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    jax give xrunit your 60 foot time and xrunit is a 12 sec truck
  4. Feb 17, 2009 at 2:07 PM
    #44
    AUDITECH
    charlotte nc
    none
    .1 at 60 foot is usually .3 at the top end
  5. Feb 21, 2009 at 1:53 PM
    #45
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Was only able to make 2 passes, weather was good. Track.. not so much.
    1st problem - no way around the water box
    2nd poblem - drying the water tracked from the water box included spreading it around on the staging lights with a mop (no heat dry, no prepping)
    3rd problem - all excess water was tracked down the first 300' or so of the track
    4th problem - trying to setup datalogging while waiting for the other racer, and not paying attention to my staging (my fault)
    Aside from those though, the weather was ideal.
    Being that track was not prepped in any way, shape, or form I opted not to use launch control. Was not able to get off the line worth a damn and my 1/8 suffered badly.
    But on my new tune, def saw an improvement in power as I pulled a new best in both 1/8 mph and 1/4 mph.
    There is a twin turbo XR that ran a 12.98 @ 106 on drag radials. So needless to say with some tires, and a good launch... my truck is capable of running in the 12's.
    Pass 1
    60' - 2.161
    330' - 5.996
    1/8 ET - 9.018
    1/8 Trap - 82.38
    1/4 ET - 13.700
    1/4 Trap - 106.27
    Pass 2
    60' - 2.285
    330' - 6.003
    1/8 ET - 8.970
    1/8 Trap - 83.58
    1/4 ET - 13.616
    1/4 Trap - 106.80
  6. Feb 22, 2009 at 1:00 PM
    #46
    AUDITECH
    charlotte nc
    none
    Yea 106 speed is deffinently a 12 sec pass. yea the e/t sucked big time you can tell traction was a problem but you were putting the power down to get 106 trap speed. I bet at a good track with nothing changed on your truck your looking at 12.7-12.9 at 108-110 speed.
  7. Mar 1, 2009 at 6:03 AM
    #47
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Even though I'm telling you nothing you don't, but your 60' needs work. Either a stickier track or as you noted tires & suspension. Maybe order some VHT and have a lane guy spray right before you run. I'm lucky in that I live near on of the stickiest tracks on FL- BMP. In my stang I would cut low 1.9's on my street tire's all day N/A. 4.10's and a 3000 stall helped.:D
  8. Mar 12, 2009 at 7:41 AM
    #48
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Yep.. this last trip out had horrible track conditions. My 60' is usually between 2.0 and 2.19 on street tires.
    I'm hoping to get a couple more trips out before the weather destroys all hopes for a 12.x pass.
  9. Mar 12, 2009 at 10:56 AM
    #49
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    its too late, youll just have to wait till next winter:p
  10. Mar 12, 2009 at 6:29 PM
    #50
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    We'll see...
    If you get a text tomorrow night that says "w00t!" and nothing else... then you can enjoy being the fastest 13 second truck, while I change my title to a "12 Second X-Runner".... :D
  11. Mar 12, 2009 at 8:11 PM
    #51
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    lol
    I just looked up your weather....rain...all day and night:p
    My track is also open tomorrow and its dry....sneaky sneaky:D
  12. Mar 13, 2009 at 6:53 PM
    #52
    AUDITECH
    charlotte nc
    none
    x runit yea werty has got you out the hole but you are making more power to pulling in on the top end. Or your a better driver.
  13. Mar 22, 2009 at 10:19 PM
    #53
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    XrunnIT your truck is totally bad azz to the bone bro.
    I wonder what my truck would do... 2wd TRD off road w/ 6speed Manual... think I could do 90+??
  14. Mar 23, 2009 at 1:36 PM
    #54
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Depending on how well you drive. It would be close. I've seen stock XR's trap anywhere from 87-93mph.
  15. Jun 15, 2009 at 11:45 AM
    #55
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    wow 2nd gen stock runs over 2 seconds faster than 1st gen (trd 4x4) my times are posted below and are unipressive.
  16. Feb 26, 2016 at 12:40 AM
    #56
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    2008 X-Runner. TRD supercharged. URD 2.8 pulley. Doug Thorley long tube headers. URD 3" exhaust. TRD intake. Stage 2 Competition Clutch. Caltracs. 26x11.50-15 Mickey Thompson ET Streets.
  17. Feb 26, 2016 at 2:59 AM
    #57
    Clearwater Bill
    Billy
    Largo Florida
    2009 thread
  18. Feb 26, 2016 at 8:15 AM
    #58
    rat107
    Kauai, HI
    2008 runs...
  19. Feb 26, 2016 at 8:28 AM
    #59
    rat107
    Kauai, HI
    http://youtu.be/05eUoiF6u6Y
    Yeah my friend's little street legal 3RZ is sure slow...
  20. Sep 24, 2016 at 11:36 AM
    #60
    kalae594
    kalae594 Member
    Mitch
    Maui Hawaii
    Altered Intentionz Sleeper...
    TRD Exhaust AFE Intake URD Y Pipe
    I have a '14 TRD Sport, 2WD, TRD SuperCharged w/TRD exhaust and 20" wheels running a 14.9...
    Any insight on tires I should get if I put back my stock 17's or even for my 20's?
    Also going to put URD Y-Pipe, 2.85 URD pulley and AFE Intake...
    Thoughts?
