1/4" of TacoLean...shimit?...or let it go?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larry, Nov 29, 2010.
  1. Nov 29, 2010 at 8:02 PM
    Larry
    Larry [OP] CARL
    CARL
    I have exactly 1/4" of lean. Both front & rear.
    As I understand it, the 1/4" shim delivers 1/2" of lift. Wouldn't I then just shift the lean to the other side?
    Stock suspension w/ TSB rear springs.
    Stock steelies and Dunlap's.
    DCSB4X4SR5
    I'm probably gonna add 5100's up front soon.
    [all ears men...and ladies]
  2. Nov 29, 2010 at 8:04 PM
    jandrews
    '09 FourDubDee TRD OR
    Shim won't eliminate it completely.
    When I put my COs on I dicked with additional preload on the driver's side forever before concluding the Taco lean can't be minimized below 1/4". I'd get it to 1/4" lean, adjust the driver's CO upward, re measure, and have gained height on both sides, retaining the 1/4" lean.
    If it's at 1/4", I'd leave it.
  3. Nov 29, 2010 at 8:40 PM
    pinktaco808
    pinktaco808 Hot Steppa
  4. Nov 30, 2010 at 4:28 AM
    jandrews
    Measure at multiple sites with the truck in multiple locales, and with the gas tank at various stages of fill. I bet you find different.
    I thought I was level as well - and I am, at times. An unnoticeable slant to the parking lot you're in, or a full tank of gas, will change things.
    My call: As long as you're within 1/4" in most all situations, call it good. That's gonna change anyway when you start loading fat friends in the cab or concrete in the bed.
  5. Nov 30, 2010 at 5:11 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Have you considered this?
    It goes between the strut and the mount. The stock studs are long enough. Simple cheap fix. Here's a pic of mine with it. No more lean.
  6. Nov 30, 2010 at 6:19 AM
    Larry
    Larry [OP] CARL
    CARL
    That's what I would use...except...
    that shim gives 1/2" of lift. Wouldn't that just move the lean to the passenger side?
    Do the math?
  7. Nov 30, 2010 at 7:17 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I had 1/4" of sag after I added my 5100's and eibach's...added the above 1/4" top spacer and now the truck it totally level. It's made for the taco lean, and does it's job well...
  8. Nov 30, 2010 at 8:57 AM
    jandrews
    I'd almost bet money you'd still have a 1/4" driver side lean and you ride height will just be 1/2" higher both sides.
  9. Nov 30, 2010 at 9:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Alot of it is also going to depend on the surface you are parked on. And, It will vary many times, even if no changes are made, and the suspension is not going to rebound to the same exact spot every time when you stop and get out. Like Jandrews said, if its within 1/4", call it good. It will vary that much just in the amount of gas, or changes in the way the springs rebound when stopped.
  10. Nov 30, 2010 at 11:16 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I did do the math and measured all 4 corners thru the center of hub from ground to top of wheel arches. Also measured from ground to level bottom part of frame near front and near front leaf mount. Got same thing from both sets of measurement....right at 7/16ths lower on front drvr corner with half a tank of gas. After using this spacer it is less than 1/8th inch different and is visually undetectable with empty or full tank of gas............See?
    Before, it was noticeable all the time.
