1/4 or 1/2 inch spacers
Discussion in 'Suspension' started by maxpower29, Jan 11, 2013.
  1. Jan 11, 2013 at 4:53 AM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    If I add the 1/4 or the 1/2 (3/4" lift) I think they are spacers. I have a couple questions. I know I will need a alignment, but will the CV angle be effected with these compaired to just my 5100s at .85 and the Eibachs? And is there a reason to why people stay away from this at all? Or is it a totally safe practice? I'm just looking for a bit more clearance with the 285s but didn't want the bigger lift of the OMEs.
    Thoughs?
  2. Jan 11, 2013 at 5:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Your angles won't be any much more affected than they already are. That should put you at 3" or very close which means you may need UCA's to get the caster in spec.
  3. Jan 11, 2013 at 5:34 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Ya I have the LR ones, I just don't want to mess the cv angles moe then they are now to keep the front end in good shape
  4. Jan 11, 2013 at 6:01 AM
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    This is the set up I have. Put 1/2 and 1/4 on driver side and just 1/2 on passenger. I got right at 3" on DCSB. It rides great.
  5. Jan 13, 2013 at 4:25 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Thanks, thinking about doing it soon. I just cant decide if I should get both 1/4" or one of each. I think after the AAL my taco lean is gone
  6. Jan 20, 2013 at 11:43 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    so is it recommended to put 2 spacers on at once? Im thinking 1/4 on the passenger and 1/2 on the drivers.
    Im sitting at 36.75 drivers front and 37 passenger. Then 39 both in the rear.
    Those are from the ground up too fender in the middle of the wheel
  7. Jan 20, 2013 at 11:53 AM
    barker14
    barker14 sexual ninja
    Adam
    Nova Scotia, Canada
    05 Tacoma TRD Off Road
    Complete OME suspension with Dakar leaf pack. Clarion touch screen Sport hood Tri fold Tonneau cover
    What are your measurements from the center of the hub up to the bottom edge of the fender? I ended up with a 1/2 inch spacer on the drivers side and an 1/8" on the passenger side. But I'm running ome's and have a heavier front end.
  8. Jan 20, 2013 at 12:00 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Im gonna have to check. Did you put the spacers on yourself?
  9. Jan 20, 2013 at 12:05 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I talked with Toytec about it and they recomended it for a full 3" of lift. I was right at 20.25" (center hub to top of fender) before and now it is right at 23.25" I wanted it for the least amount of rubbing. It has not given me any problems so far.
  10. Jan 20, 2013 at 12:07 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    do you have aftermarket UCAs? And how are the angles of the CVs?
  11. Jan 20, 2013 at 12:09 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    My angles are good. I have LR UCA.
  12. Jan 20, 2013 at 2:10 PM
    barker14
    Adam
    Nova Scotia, Canada
    Yeah I put them in when i did the lift. I actually made them too. One thing I just remembered is that if you run spacers larger than 1/4 you will need longer top plate studs as well which means Breaking down the suspension and pressing the old ones out.
  13. Jan 20, 2013 at 5:03 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    True^^^^^
  14. Jan 21, 2013 at 2:25 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I just wondering with the weight difference up front what I should go with. I might call them and see what they think
  15. Jan 21, 2013 at 11:44 AM
    barker14
    Adam
    Nova Scotia, Canada
    1/4" spacers should put you up 1/2" how much height did you get from the lift? Did you take before and after measurements?
