1/4" Spacer on 5100 or Eibach system
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Evdunn, May 14, 2021.
  1. May 14, 2021 at 11:11 AM
    Evdunn
    Evdunn [OP] Well-Known Member
    Evan
    Edmonton, AB Canada
    2020 Black Tacoma TRD Off Road
    Does adding the taco lean spacer on top of these systems cause any loss of ride quality or effect the shock in any negative way?
    I know people are pretty adamant against spacers, but I never see any negatives talked about with this.
  2. May 14, 2021 at 11:42 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Totally fine :thumbsup:
    kas2828 likes this.
  3. May 14, 2021 at 11:57 AM
    manncyclesupply
    manncyclesupply Well-Known Member
    Mark
    Athens, GA
    2021 dclb TRD Sport 4x4
    2nd that :thumbsup:
    71tattooguy likes this.
  4. May 14, 2021 at 12:19 PM
    Evdunn
    Evan
    Edmonton, AB Canada
    My next question would be, since the top clip is reserved for extra weight and provides a rough ride on the Eibach otherwise.
    Would there be any harm in going to second clip (2.5") and 1/4" spacers on both sides to acheive 3"
    I know there's better ways, but apart from all new suspension. Is this a bad idea?
    CaptainBart45 likes this.
  5. May 14, 2021 at 12:22 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    You could do that. Did you get UCA’s ? Also ECG’s bushing?
    Evdunn[QUOTED][OP] likes this.
  6. May 14, 2021 at 12:25 PM
    Evdunn
    Evan
    Edmonton, AB Canada
    I already did the ECG bushing, I'd have to get UCA's if I go this route which would be the plan. I know it's kind of bastardizing a lift, but I do light offroading (fire roads, camping/fishing trails) and most of my driving is highway/daily driver
    71tattooguy[QUOTED] likes this.
  7. May 14, 2021 at 12:31 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Sounds good bro. You will be fine.
  8. May 14, 2021 at 12:49 PM
    manncyclesupply
    Mark
    Athens, GA
    I’m running bilstein 5100’s, OME coils, SPC UCA’s and Icon AAL. Also 1/4” spacer on drivers side. ECGS bushing and CMC.
    The truck rides great on pavement and fire road type trails.
    Durango95 and Evdunn[OP] like this.
  9. May 14, 2021 at 12:59 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Exactly what I did on my 6112's. I used lower spring settings and 1/4 inch spacers.
    manncyclesupply and Evdunn[OP] like this.
  10. May 14, 2021 at 1:03 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Put it this way, I put a 2" spacer on my truck when it was brand new and it drove exactly the same as it did the day I bought it. I am however aware I do not want to do heavy off roading with it and will be going with 5100's shortly.
  11. May 14, 2021 at 1:06 PM
    Evdunn
    Evan
    Edmonton, AB Canada
    I had a 2" spacer on mine first as well. Noticed no rode quality difference then stock.
    I upgrade to Eibach shocks and springs a couple of months later and the ride quality was greatly improved.
    I had no issues with the spacer as you said.
