1/4" spacer ????
Discussion in 'Wheels & Tires' started by kwalton, May 12, 2008.
  1. May 12, 2008 at 6:32 PM
    kwalton
    kwalton [OP] Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    i bought some pro-comp wheels from the local 4 wheel parts and it turns out that they hit the calipers. what a suprise???? has anyone used 1/4" spacers to remedy this. i am just worried i won't have enough thread on the lugs and grinding the calipers is not an option for warranty issues. thanks for any help.
  2. May 12, 2008 at 6:41 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I have 1/4" spacers on my front hubs. Are they aluminum or steel wheels?
  3. May 12, 2008 at 6:55 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    With my steelies, I had to get conical lug nuts. I'm comfortable with the amount of thread the lug nuts have. What bothers me is the cheap construction of the spacers and the fact that they eliminate the abillity of the wheels to center on the hubs as oposed to the lug nuts. That being said, after 4 months of daily driving and some offroading, I havn't had any problems.
  4. May 13, 2008 at 2:42 PM
    zmtnbik
    zmtnbik FMLYHM
    4x4 Trd Off-road
    Donahoe (Icon) C/O, TC UCA's, Dakar leafs, BilStein 5125's, 285/70/17 BFG MT KM2's, Raceline Renegade 17x9's, u-bolt flip kit, debadged, TRD CAI, TRD exhaust, URD MAF controller, 20% front window tint, 3M clear bra on bumper, cam locks in all storage compartments, fog light mod, Alpine X100 deck, Co
    I know there are some that are against griding the calipers....why not grind the rims? You are only removing a small amount of material and it's on the inside of the rim that you will never see. As long as the amount of material removed is pretty equal, balancing shouldn't be an issue either.
  5. May 13, 2008 at 2:55 PM
    06tacomaprerunner
    06tacomaprerunner the foreigner
    B. C. Mex.
    06 PreRunner SR5 dbl cab shortbed, r
    BILSTEIN 5100, 1/4 inch wheel spacers,removed front mud flaps, 285/70/17 bfg mud terrain km2 and a lot of scratches in front and rear bumpers
    I have been used them for like 3 months, and I havn't had any problems.
  6. May 13, 2008 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This would be a big no no. Rims have a rating for weight. They are manufactured to be able to handle the rotational forces at high speeds, carrying a load, stopping a vehicle, lateral forces, etc. By grinding the rim and not knowing what you are doing, you will severly compromise the integrity of the wheel. Looseing a caliper on the freeway is bad, loosing your whole wheel is much worse. Get the spacers. If they dont work for ya, get a different set of wheels.:)
  7. May 13, 2008 at 3:09 PM
    kwalton
    Baltimore, Md
    thanks for all the replies. i went ahead and ordered them today along with the conical lug nuts. i have run large spacers before on all my vw's but with them you can replace the the whole lug bolt with longer ones so that is why i asked. thanks again.
