1/4" top plate spacer on bilstein 5100's
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madams, Apr 8, 2011.
  1. Apr 8, 2011 at 3:00 PM
    Madams
    Madams [OP] Well-Known Member
    South Carolina
    They call it barney
    If I want to get 3 inches of lift up front can I add a 1/4" top plate spacer on top of 5100's. Can I do this or not?
  2. Apr 8, 2011 at 3:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes.
  3. Apr 8, 2011 at 3:02 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Are you talking with stock coils? there is a top plate spacer you can add but I would just but new coils the Eibachs are not that much and will give you 3"+ and ride way better.
  4. Apr 8, 2011 at 3:15 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I put in the 1/4" spacer on the left 5100 to make up for the taco lean.
  5. Apr 8, 2011 at 3:16 PM
    Madams
    South Carolina
    They call it barney
    Yes stock coils. I would rather have the 3/4" top plate spacer. dont know why I put 1/4".
  6. Apr 8, 2011 at 3:17 PM
    JLee
    Jerry
    Benicia, CA
    I thought that was only 2nd Gens? mine don't lean :notsure:
  7. Apr 8, 2011 at 3:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Nope.
  8. Apr 8, 2011 at 3:19 PM
    JLee
    Jerry
    Benicia, CA
    I think a 3/4" space will take you way over 3" with the 5100's set at 2.5 I still recommend just buying new coils it's about 150.00 for the Eibachs and it's well worth it.
  9. Apr 8, 2011 at 3:21 PM
    JLee
    Jerry
    Benicia, CA
    I guess I'm one of the lucky ones then :D oh wait my truck does lean just look at my sig ;)
  10. Apr 8, 2011 at 3:21 PM
    Madams
    South Carolina
    They call it barney
    Well I want enough lift for 33's 1/4" spacer should be fine to get 33's instead of 3/4" cause I dont want to go over.
  11. Apr 8, 2011 at 3:24 PM
    JLee
    Jerry
    Benicia, CA
    Yeah 1/4" is the most I would go I don't even think you could get a 3/4" spacer in there safely with the 5100's at 2.5
  12. Apr 8, 2011 at 3:32 PM
    Madams
    South Carolina
    They call it barney
    Tell me more about the eibach springs. I just looked on the web site and couldnt find the springs for my tacoma. Could I run them with stock shocks in the front and they will lift my truck over 2.5 inches
  13. Apr 8, 2011 at 3:38 PM
    JLee
    Jerry
    Benicia, CA
    NO! YOU CAN NOT RUN THEM WITH STOCK SHOCKS. it's a valving issue you need to buy 5100's there might be other shocks you can run them with but not stock.
  14. Apr 8, 2011 at 4:43 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Me too. Mine doesnt lean either! :)
    X2. :cool:
  15. Apr 8, 2011 at 8:23 PM
    Madams
    South Carolina
    They call it barney
    Mine leans a little to the drivers side not much.
