1/4 top plate spacer ?
Discussion in 'Suspension' started by MAG GRY TACO15, Oct 26, 2018.
  1. Oct 26, 2018 at 7:25 AM
    MAG GRY TACO15
    MAG GRY TACO15 [OP] Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    I'm planning on putting my 5100's and 885x coils on this weekend. I got a 1/4 in top plate spacer to help with the taco lean. Should I install that too or wait until things start to settle down the road? it's not a big deal to pull the driver side coil over and install the spacer later.
    I plan on an alignment few days after the install. And would probably do the same if the spacer was needed down the road.
    jafrisi likes this.
  2. Oct 26, 2018 at 7:39 AM
    jafrisi
    jafrisi Well-Known Member
    Tucson, AZ
    14 Superwhite DCSB TRD OR
    Toytec bilstein 5100 lift w AAL. 2.5 front and 1.5 rear. KMC turbine wheels 4.5 bs, BFG KM3s 285/75/16
    How bad is your lean? Mine was almost an inch different. If yours is less maybe you won't mind it, or maybe to the new coils will help correct. You could wait and see, it's easy to do during or after the lift. Your call.
  3. Oct 26, 2018 at 10:31 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    I don't really even see a lean on mine but it's only got 25k miles on it too. I assume with the new coils and shocks it will take some time to develop a lean and figured I'd deal with it then of it happens.
    Aside from the ease of having everything apart now for install is there any downside to waiting?
  4. Oct 26, 2018 at 12:35 PM
    jafrisi
    Tucson, AZ
    No, a lot of people get the taco lean right away. Mine was like it from the factory.
