1/4 Toytec spacer install question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oey12, Jan 11, 2015.
  1. Jan 11, 2015 at 5:45 PM
    Oey12
    Oey12 [OP] Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    I have a few questions for any of you who have installed the toytec 1/4 top spacer. Can I just remove the top three stud bolts on top of the coil/spring assembly and slide the spacer over? And if not do I have to remove the bottom shock bolt as well or do I pretty much need to take apart everything just to slide it over the top? The spacer is going on a stock sport coil/shock. Thanks for any input...
  2. Jan 11, 2015 at 5:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's just a top plate spacer
  3. Jan 11, 2015 at 5:56 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm guessing the easiest way to do this is
    1. jacksands under the frame
    2. drop the 2 bolts that hold the lower-control-arm to the spindle
    3. remove the three nuts holding the shock coilover assembly in place
    4. swing the lower-control arm down, lowering the coilover assembly to gain access to the top
    5. add the spacer
    6. add the bolt extensions
    7. reverse steps 1-4 to reassemble everything.
  4. Jan 11, 2015 at 5:56 PM
    Oey12
    Joe
    New York
    I want to go with a mild lift, anywhere from a 1/2 to 1 inch would be perfect on my truck. I am afraid the Bilstein 5100 will cause vibrations...seems to me like its 50/50.
  5. Jan 11, 2015 at 5:58 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's only a 1/2" thick spacer providing a little less than an inch of lift.
    Useful if you've e.g. added a heavy bumper that caused the front to droop.
  6. Jan 11, 2015 at 6:13 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I did a set of 1/4" top plate spacers on my truck last week. It actually turned out to be a HUGE pain in the ass. Granted, my truck is already lifted on 5100s set at 1.75" so maybe that played a part as the over all strut assemble is a bit taller.
    But, I had to unbolt the 2 lower balljoint bolts, the sway bar bolt, lower strut bolt, and the 3 strut mount top bolts. Then I had to stick a big prybar between the frame and lower control arm and pry the lower control arm down enough to slide the bottom of the strut out. The bushing on the control arms dont allow the control arms to pivot far enough to just lower the strut to slide on top plate spacers on. However, when you attempt to pull the strut assemble down, itll hit the sway bar and take a bit of persuasion to get it to drop low enough. At this point, the top of the strut mount is low enough to get the top play spacers on. Then you have to wrestle the strut assembly back in place while you pry the control arm down to get the strut bottom in place. Youll need a few prybars and an extra set of hands.
    Again, this could be from it already being lifted that made it a huge pain in the ass.
  7. Jan 12, 2015 at 3:00 PM
    Oey12
    Joe
    New York
    After changing the oil and rotating my tires today I decided to try to install the 1/4 spacer. I took apart the top 3 bolts, the bottom of the shock, and the bottom 2 bolts spindle to lower control arm which then I decided to stop. First off barely anything was budging and I only gained about 1/8 inch between the top of the coil assembly and the bottom of the mount. I also tried to push the lower arm down with a steel bar and that accomplished nothing so I figured the only way to do this is to take apart the entire front end as if I was installing a new coilover. In the end I give you guys a lot of credit for doing your own suspension work because this task was well beyond my skill set. And I figured all this work isn't worth a 1/2 inch lift... Honestly is it even worth having a shop do it?? If I may going to have someone pull it apart I might as well install 5100's but I am concerned about vibrations at .85. Any in put is appreciated ...
  8. Jan 12, 2015 at 6:29 PM
    steveo27
    Pittsburgh
    Do it all at once if youre going to do it.
    My 5100s are set at 1.75" on stock springs and theres no issues.
  9. Jan 12, 2015 at 8:01 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I did the 5100's set at 0 with the OME 883x coils . It gave me just under 2in. on the pass. side and about 1 9/16 on the driver side . Damn taco lean. It rides great with no issues . The only regret is I wish I would of done the spacer on the drivers side for the taco lean and for the same issues you had is why I had a shop do the install. It was well worth the money.:D
  10. Jan 12, 2015 at 8:18 PM
    JohnB81
    JohnB81 Well-Known Member
    OC
    2018 Tacoma TRD Sport 4x4 DCSB
    trifold solid bed cover (Amazon) Pop & Lock tailgate auto lock LED Headlight/ fog lights, reverse lights, dome/plate lights AVS ventshades Smartliner front & rear floor mats Rough Country neoprene seat covers BHLM NiLight LED strip bed lights NiLight RGB LED strip lights behind rear seat storage NiLight RGB LED strip lights for under hood and behind the grill lighting NAVIKS Apple CarPlay interface on stock Entune system Auxbeam auxiliary fuse box/ switch controller Auxbeam custom fit switch panel (Etsy) Coin holder bucket (Etsy) Center console organizer HookeRoad center console vault 32” Slim LED light bar mounted on CaliRaised Offroad lower bumper brackets Suparee sequential turn signals in black smoke OEM bed mat Sokie Tech hood struts 14” Hood scoop LED light bar RGB Raptor lights with smoked lens K&N air filter with TRD air intake accelerator K&N cabin air filter ViAir portable air compressor TuffSkinz interior red color accents on doors and center console TRD faux Pro shift knob w/ TVD TRD decal Glove box letters from Tacos4Cheap MESO customs chrome delete MESO customs door handle blackout covers MESO customs minimalist key fob V1 & V2, red MESO buttons MESO customs puddle lights MESO customs dual color map lights Matte black steering wheel overlay TVD matte black glove box overlay Pedal Commander A/C drain mod Red/Black paracord grab handles Red seat pull straps LOSTAR faux Pro skid plate Rockville 8” powered subwoofer CaliRaised LED catalytic converter plates Hooke Road tailgate panel Rok-Block tailgate gap seal Rear cab USB mod (idea from @ClassyTacos) Xprite RGB rock lights Falken Wildpeak MT 285/70/R17 Painted calipers red w/ TRD decal Akebono brake pads eBay seat jackers 4WP rock sliders DS18 tweeters DS18 front speakers Bought it with: Black Rhino Hammer wheels Spacer lift 285/75/17 Toyo MT’s TRD Pro Grill Hertz Audio speakers/ KENWOOD tweeters
    I agree with doing the entire install at once. Not worth pulling the front end apart 2 times and having it aligned twice.
    Follow a video like this one and you should have no problems. Feels super safe and relatively easy, just time consuming.
    https://m.youtube.com/watch?v=vkVLBOnAifc
    Bilsteins set at .85 for me and no excessive vibrations felt. I had vibrations prior to my install ( typical 60-70 mph vibes, likely tire balance)
    Good luck!
  11. Jan 12, 2015 at 9:59 PM
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    Boom, do this !
    1) be careful lowering the truck/compressing the coils
    2) you're gonna want more lift
  12. Jan 12, 2015 at 10:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    There should be no vibrations if you keep the lift at- or under 2". After all, the factory TRD Pro and Baja packages lift 2"...
    Look into Rancho Quicklift 2" lift complete strut assemblies so you don't have to dick around with spacers or spring compressors.
    These came on the market ~2011, so they are newer than Bilstein 5100s and aren't as well known. A few guys here run them and like them.
  13. Jan 12, 2015 at 10:12 PM
    n.gardner
    Nick
    Hawaii
    '13 SR5 4x4
    Alotta guys on the ford explorer forum (my last truck obsession, see profile pic) ran the rancho struts, all good reviews
  14. Jan 12, 2015 at 10:13 PM
    KenLyns
    Belly of the Beast
    And a passenger-car scissor jack wedged between the lower control arm and the bumpstop bracket works a lot better than prying down on the lower control arm. :cool: I used the one from my Subaru.
  15. Jan 15, 2015 at 9:28 AM
    Oey12
    Joe
    New York
    I really want to give this one more try, my next question is what keeps the lower control arm from going down??? Is there some sort of spring or mechanism? This seems to be the only reason why I can't get the shock down. I think I am going to try the scissor jack approach but I am want to do as much research as possible to be prepared for any more problems. And I have decided to wait until I need new shocks before I upgrade to the 5100's. Thanks again guys appreciate the help.
  16. Jan 15, 2015 at 9:34 AM
    KenLyns
    Belly of the Beast
    ^When torqued down, the lower control arm inboard joints are no longer rotating joints but flextures. (The flex comes from the rubber bushing material.)
    If you loosen the lower control arm bolts, the arm can swing down 90 deg. This doesn't always work due to corrosion, but is worth a try. Use a paint marker to mark the alignment cam positions prior to loosening.
    "Performance" control arms typically use urethane bushings. Since urethane doesn't flex as much as rubber, the bushings need grease reapplied every 6 months to a year to function correctly.
  17. Jan 15, 2015 at 11:16 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yep. Loosen the bolts at the alignment cams after marking their positions. I should have called that out above.
  18. Jan 15, 2015 at 12:22 PM
    Pigpen
    Dan
    Northwest Montana
    With the sig pic, you lost me at scissor....
    Ping likes this.
  19. Jan 15, 2015 at 4:49 PM
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    use the scissor jack or port-a-power method. that will give you enough room to get the spacer in.
  20. Jan 15, 2015 at 4:50 PM
    nj636
    Kev
    Jersey
    I used a porta power
