1/4" Toytec spacer install?
Discussion in 'Suspension' started by Fabulous, Sep 15, 2010.
  1. Sep 15, 2010 at 7:57 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I put my lift in a week ago, and I have my alignment on Friday...so I went out to measure the lift, and it looks as though the drivers side did end up about 1/4" lower than the passengers side :( To install the Toytec tacolean spacer, do I have to pull the whole assembly out again? Like remove the sway bar all over again, and pull it completly out? It would be a major pain in the ass if I had to, but if I have to, then I have to...
    Anyone have any ideas?
  2. Sep 15, 2010 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yeah, You have to set the spacer on top of the spring/;shock assembly.
  3. Sep 15, 2010 at 8:13 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    put the spacer in before you realign
  4. Sep 15, 2010 at 8:13 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  5. Sep 15, 2010 at 8:57 PM
    Fabulous
    Fabian
    Calgary, AB
    I figured as much with the install prior to align...just wondered if I had to pull the whole assembly back out. Guess I'll be back in the garage again tomorrow night.
