1\4 wheel spacers.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oktacomaldc, Sep 7, 2020.
  1. Sep 7, 2020 at 9:01 PM
    Oktacomaldc
    Oktacomaldc [OP] Active Member
    Brandon
    2017 white tacoma sr5
    Stock
    Ok, guys i need some suggestions. I recently purchased a 2015 tacoma with a 1.5 inch lift and 275\70\17 tires. The tires rub the uca at times so how do i safely install 1\4 wheel spacers without jeopardizing safety.
  2. Sep 7, 2020 at 9:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You don't. Either change the wheels to give you more backspacing, change your UCA to give you more clearance, or change the tires to be a narrower tire. 255/75/R17 is about the same diameter and weighs much less and would clear the UCA rubbing issue.
    Greenedmc likes this.
  3. Sep 7, 2020 at 10:57 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    I’ve run 1/4” spacers for years without issue. Just get extended thread lugs and you’ll be fine.
    Oktacomaldc[OP] likes this.
