1.5" AAL Installed..Now Some New Issues
Discussion in 'Suspension' started by sac130e, Apr 30, 2011.
  1. Apr 30, 2011 at 12:14 PM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Currentlu had up front: 5100's at 0 setting with OME 884 Coils and LR UCA's. Back had the TSB and 5100's installed, and beside some alignment issues, rode fine.
    Today installed the 1.5" AAL and some new issues seem to have developed and wondering if anyone else has heard/seen this.
    1. From a stop with normal acceleration, it feels like the truck shutters for a few seconds whle accelerating. Goes away after the speed increases, but very odd to have this now and not before.
    2. When coming to a full noram stop, the truck will rock back and forth a few times before stopping. Kind of like a jiggle, where it used to lunge forward when coming to full stop then back and stop rocking. Now it seems to 'Jiggle' back and forth a few times before stopping, like its suspended in jello. Maybe normal for this setup, just seems odd to start now.
    Thx,
    Scott
  2. Apr 30, 2011 at 3:46 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Thats a normal drive shaft vibe associated with lifting. you can buy a carrier bearing drop kit and that should eliminate.most of your vibes.
  3. Apr 30, 2011 at 5:20 PM
    sac130e
    Scott
    Milton, FL.
    From the post here, thought that was only viable for 4x4's? I have a 2wd so didn't purchase that kit.
    Scott
  4. Apr 30, 2011 at 5:25 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sounds like you need the CB drop as mentioned earlier .
    Also sounds like you have some axle wrap .
    I think you are confusing CV and CB .
    Only the 4x4's have CV's , but all Tacoma's except Regular cabs have a 2 piece driveshaft and carrier bearing .
  5. Apr 30, 2011 at 6:01 PM
    sac130e
    Scott
    Milton, FL.
    Is this axle wrap bad for the truck and can it be fixed?
    I have the TSB and 1.5" AAL on the rear, should I remove the AAL?
    Truck is only 2 months old, don't need to do any premature damge to it just yet.
    Thx
  6. Apr 30, 2011 at 6:46 PM
    sac130e
    Scott
    Milton, FL.
    Researched the axle wrap thing and am pretty sure this in't what I feel. I have no thumping sound or feel the back wheels hop at all. Have 5 brand new springs on the rear, so pretty sure that's not what I feel.
    What I feel is the entire suspension rock to and fro..(very slighty) a couple times when coming to a full stop. No noise or wierd behavior, just seems the suspion is sponge (for a second, till it stops). This may just be a caracteristic of the new suspion being entirely new and not stock anymore.
    As for the CB thing, didn;'t think I needed that, but if it is recommend, then I will grab one next week. Are they difficult to install..and do you need alignment after putting it on?
    Thx
  7. Apr 30, 2011 at 7:10 PM
    sac130e
    Scott
    Milton, FL.
    All required torques were set to 75ft-lbs.
    I don't have a vibe..its just a very slight shudder (sometimes) from a stop till about 2-3 seconds later (less than 5mph) then its gone. I will get another alignment this Monday and hopefully (if they get it right this time) will compensate for the install of the rear AAL.
    Thx
  8. Apr 30, 2011 at 7:12 PM
    DevL
    DevL Well-Known Member
    The rocking is indicative of shocks with too little rebound damping. The vibration is the need of the carrier bearing drop.
  9. Apr 30, 2011 at 7:27 PM
    sac130e
    Scott
    Milton, FL.
    Is this bad for the truck and the shocks..is there a way to fix it or let it ride for abit since its still new and see if it works its way thru.
    I unsderstand the CB drop kit, just not sure if that will fix what I have, since I don't have any vibration, just a very slight shutter from stop till 5mph..and not all the time.
    Thx
  10. Apr 30, 2011 at 7:29 PM
    OZ-T
    Peter North
    British Columbia
    The CB drop is like $15 and will take you 20 minutes to install . It is worth trying .
  11. Apr 30, 2011 at 7:32 PM
    OZ-T
    Peter North
    British Columbia
  12. Apr 30, 2011 at 7:34 PM
    sac130e
    Scott
    Milton, FL.
    Thx, I will give it a try.
    On second thought..anywhere else to buy this from.
    Toytec wants 13.oo to ship it..no F*** way I am paying more for shipping then the cost of the item
    Thx
  13. Apr 30, 2011 at 7:37 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    I'd try the CB drop as listed above by OZ-T and torque those bolts to 100 ft. lbs minimum. Same with your new U-bolt nuts. Make sure those are torqued down to 100 ft. lbs. I had some vibe issues when I installed the same lift. Mine are all gone now with the steps listed about.
  14. Apr 30, 2011 at 7:38 PM
    KalamaKid
    And don't worry about the axle warp or carrier bearing vibes causing damage, you'll be fine for now.
  15. Apr 30, 2011 at 7:40 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Recomended torque on carrier bearing is around 30 lb/ft.
  16. Apr 30, 2011 at 7:41 PM
    OZ-T
    Peter North
    British Columbia
    Keep the $24 in your pocket and just live with the vibes when you drive your $30 000 truck .
    Problem solved .
  17. Apr 30, 2011 at 7:42 PM
    sac130e
    Scott
    Milton, FL.
    29350.00
    haha
  18. Apr 30, 2011 at 7:45 PM
    KalamaKid
    Where do you see that? My manual says 50? I had it at 50 but still had a small vibe. I put it up to 100 and now no vibes at all? If i'm wrong though please don't blame me if you break a bolt:p
  19. Apr 30, 2011 at 7:46 PM
    sac130e
    Scott
    Milton, FL.
    Isn't overtorque bad? If so, my whole front end is going to fall off one day.
    :D
  20. Apr 30, 2011 at 7:51 PM
    KalamaKid
    overtorque is bad when there is something that needs a certain amount of space to flex or move. Like in an engine. You don't want to over torque anything on the head as it will heat up and expand. But as for a bolt that wraps around your axle overtorque isn't really going to hurt anything. But if again i could be wrong...
