1.5" AAL with TSB or 2" AAL NO TSB
Discussion in 'Suspension' started by EmoSlayer, Nov 11, 2012.
  1. Nov 11, 2012 at 10:26 PM
    EmoSlayer
    EmoSlayer [OP] METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    Hi all, been searching around and can't really find a specific thread that covers this. I am about to put on eibach coils and billy 5100 @ 0.85 setting, my question is does it make sense to have tsb done and then a 1.5" aal (this would be 5 leafs total)? or just go with a 2" AAL and have 4 leafs total? I had a 2" AAL on my previous tacoma and it sagged pretty bad after only a couple of months. I have a 250 pound apprx leer cap on this one and it's bottoming out bad stock. Would 4 leafs reduce possiblity of rear take-off vibes vs the 5 leaf combo?
  2. Nov 12, 2012 at 5:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What total lift do you have in the front?
    With that much weight in the back...I WOULD NOT get an AAL.
    Get a NEW aftermarket leaf pak that's designed to lift your truck (to match the front) AND be able to support the 250lb cap.
    Do it right the first time.... An AAL (no matter what leaf pak its paired with) WILL SAG with that much weight on it over time.
  3. Nov 12, 2012 at 6:18 AM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    I was hoping to get the max lift in the front without getting uca's. Seems as though ppl on here have had good luck with 1.6" eibach and 0.85" 5100 for 2.4" apprx lift up front without needing uca's. What new leaf pack would you recommend to handle the weight, minimize sag, and achieve 2" of rear lift, my truck has only a slight rake due to the cap. I prefer rake over level, and i def dont want a sagging rear, thats what she said.
  4. Nov 12, 2012 at 6:25 AM
    rubenc87
    rubenc87 Cobra
    Texas
    2013 Tacoma DCSB 4x4
    DTRL,HID's, Redline Elite Hood Struts,IVD Coilovers and Rear Shocks W/ Ext. Res.,N-FAB Light Bar W/ KC Titanium Lights, Alcan AAL,Wet Okole's, URD T.C.A.I. M/T Classic Lock's BFG AT, Chrome TC UCA'S,TRD Exhaust, Bed Mat,Painted Roof Rack,Access LE,Weathertech's F&R,P&L Lock
    The big difference is the cap. I agree. Do it right the first time. I would think that the leaf spring Co. Would know best how to build them for your specs.
  5. Nov 12, 2012 at 7:44 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    What if I did TSB with 1" rear block, I already have the block from toytec from when my rear had sagged on my previous taco, just never installed em. With this I'd set the billies at 1.75". I wouldn't have to worry about the blocks sagging... would I need even longer U bolts then the ones that came from toytec if I had TSB installed? Also would I need 5100s in the Rear with this setup?
  6. Nov 12, 2012 at 8:12 PM
    Janster
    Jandy
    Lancaster, PA
    Are you able to get the TSB for free under warranty?
    If not... I wouldn't buy them. You can find better aftermarket springs that'll have a higher spring rate (to support that 250 lbs).
  7. Nov 12, 2012 at 8:45 PM
    EmoSlayer
    Scott
    PA
    TRD Off-Road
    Yea it's still under warranty, only have 9k miles on it haha, only have a 0.5 mile commute to work :D
  8. Nov 12, 2012 at 9:38 PM
    rubenc87
    rubenc87 Cobra
    Texas
    I don't recommend the blocks in the rear.
  9. Nov 12, 2012 at 9:40 PM
    Janster
    Jandy
    Lancaster, PA
    Have you even tried to get the TSB for free under warranty?
    I don't think it's as easy to get them now as it was 5 years ago.
