1.5" on the front of a 1st gen?
Discussion in 'Suspension' started by Pescado, Feb 28, 2016.
  1. Feb 28, 2016 at 8:59 AM
    Pescado
    Pescado [OP] Well-Known Member
    Vancouver
    2002 Lunar Mist TRD DC
    265/75/16 BFG KO2, Pro Comp 7069, General Springs HD leaf pack, Bilstein 5100's, Snugtop Canopy
    I'm looking to get 1.5" without preloading the coils but without a good solution yet. 881's seem too much (up to 2.5" from some accounts) and 880's not enough.
    My current best and nearest answer is stock coils with middle bilstein setting of 1.25".
    So just have to throw this Hail Mary out there before I pull the trigger. Is there any way to get approximately 1.5" on the front of a 1st gen double cab V6? Preferably without preloading.
  2. Feb 29, 2016 at 8:34 AM
    Pescado
    Vancouver
    I guess another way to ask this question is, what other options are there for coils in the 1-2" lift range for our trucks? Is there anything outside of OME with a less than 2" but more than stock lift height?
  3. Mar 5, 2016 at 2:32 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    You can go the 1.25" Bilstein 5100 route with your factory coils, tophat spacers and longer studs. I just did mine with factory TRD coils and the ride is not bad at all.
  4. Mar 5, 2016 at 2:43 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Check out rancho quick lift assemblies
  5. Mar 5, 2016 at 7:44 PM
    Pescado
    Vancouver
    Thanks for the suggestions. I did look at the quick lifts but discovered them the same day I ordered my 5100's.
    @xcmtb83 i might have to pm for the details. Sounds like that might work perfect for me!
  6. Mar 11, 2016 at 6:50 PM
    epfatboy
    epfatboy Member
    Eric
    Looking to buy one
    None yet but will do small lift
    Looking for a similar setup but maybe more like 2.5". A tophat spacer and 5100 (stock coil) seems to be a good combo. The rear will probably be a lift block, I think 1.5" will do. Need rear shocks too, not sure what I need there. Don't want to hijack but if someone has an inexpensive recommendation with part number I'd appreciate it.
    I think the ride should be good and the cost is decent also. Pretty sure the pre-load needed isn't significant
  7. Mar 11, 2016 at 6:52 PM
    epfatboy
    epfatboy Member
    Eric
    Looking to buy one
    Oh forgot to mention I'm hoping to squeeze a 33x10.5 tire in there. Think I need a wheel spacer and probably just a little trim.
  8. Apr 11, 2016 at 1:15 PM
    Pescado
    Vancouver
    wanted to give a little update. Finally installed Bilstein 5100's all around with General Springs HD in the rear and stock coils with 1/4" top hat spacers in the front. The ride is tremendously better than the stock setup. The lift is subtle and still makes my 265/75/16 tires look relatively well proportioned for my taste. Thanks for the help from those who made suggestions especially @xcmtb83
    Final tally is about 1.5" rear (already had 5 leaf pack in the back) and 1.5" in the front.
    Here's a few pics of the new setup:
    boostedka, xcmtb83 and SwampYota like this.
  9. Apr 11, 2016 at 9:22 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    That setup looks good. Any rubbing? I see you removed the front mud flaps.
  10. Apr 11, 2016 at 9:34 PM
    Pescado
    Vancouver
    Thanks! There was some rubbing prelift on the passenger front when the wheel was turned all the way to right, but luckily it's got enough clearance now.
    May give the paint a break and try to put the mudflaps back on now.
  11. Jun 22, 2016 at 1:29 PM
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    I may go this same route, truck looks very good. Nice job. Does the truck look even on flat ground when looking at directly on the side or is it a little raked?
  12. Jun 23, 2016 at 10:38 PM
    Pescado
    Vancouver
    It looks even if you look at it from the side. If you look at it from the rear the back looks slightly higher, but that may just be a perspective thing. I'm planning on taking off the canopy in a few weeks to see if I can get a little rake (which is my preference).
  13. Jun 24, 2016 at 10:15 PM
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    How much do you think the canopy weighs?
  14. Jun 24, 2016 at 10:33 PM
    Pescado
    Vancouver
    Probably 150-200lbs. It's a snugtop.
  15. Oct 27, 2016 at 9:02 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    @Pescado just wondering hows ur set up still doing . aim going to set my with billis and a aal . what setting did u have urs billis with the stocks trd's coils ?
    hows the ride feel after a few months of running this set up .
    Any input would be a preciated .
  16. Oct 27, 2016 at 9:04 AM
    eon_blue
    Azusa, CA
    FWIW I got the 881s on my truck and got nowhere near 2.5" of lift out of them, in fact I'm pretty sure OME says 2" is the max lift to expect out of the 881s. I ended up with about 1", v6 4x4 so I have some weight in the front but I was a little disappointed as I was hoping for the 2 that they advertised. Juts a heads up for anyone looking at 881s.
    Pescado[QUOTED][OP] likes this.
  17. Oct 27, 2016 at 9:20 AM
    taco03Trd
    Carlos
    Riverside ca
    Thanks @eon_blue good input was thinking to get 881 coils i have the v6 2wd . pescado's set up looks good with stock coils . hopefully is riding good too .
    That's my plan B option if i dont go with new coils . o_O
  18. Oct 27, 2016 at 9:33 AM
    Pescado
    Vancouver
    I'm still very happy with this setup. Reading eon_blue's reply I will likely pick up some 881's at some point, perhaps when the current tires need replacement and possibly go up a size to 285/75/16.
    But bottom line this set up is very comfortable, firm but not jarring. I would do it again or recommend the same for someone looking for a subtle lift without hesitation.
  19. Oct 27, 2016 at 10:06 AM
    taco03Trd
    Carlos
    Riverside ca
    Great thanks forthe input @Pescado what settings u have ur billis at ? i have a v6 2wd
    Ill probably get new springs next year .
    Again thanks for the input . truck looks good pescado :thumbsup:
  20. Oct 27, 2016 at 10:27 AM
    Pescado
    Vancouver
    You're welcome and thanks for the compliment.
    Bilstein's are set to the middle 1.25" setting on stock 4wd v6.
