1.5" or 2" aal
Discussion in 'Suspension' started by 757southpaw, Nov 19, 2009.
  1. Nov 19, 2009 at 9:09 AM
    757southpaw
    757southpaw [OP] Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Looking for a level look as i proceed w/ lifting my 07' 4x4 d/c tacoma! I plan on installing the 5100's on all corners and setting the fronts to 2.5". Which aal should I purchase...1.5" or 2"? My truck currently has the stock rake but not sure how much of one. It also has the 3 leaf pack! Thanks in advance!
  2. Nov 19, 2009 at 9:11 AM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    1.5 to be level.
    oh , and hello neighbor.
    here is a pic of the 2.5 lift w/ 1.5 aal.
  3. Nov 19, 2009 at 9:24 AM
    757southpaw
    Jay
    757
    Thanks neighbor! Where in Hampton do you live? Also did you attach a pic? I'm a newbie still learing the site!
    I'm thinking the ToyTec or Wheeler AAL! Any preference and do you know if any payload is added?
  4. Nov 19, 2009 at 9:26 AM
    757southpaw
    Jay
    757
    oh! I see pic now...looks pretty damn good!
  5. Nov 19, 2009 at 9:31 AM
    CAMZTRD
    steve
    hampton, va
    i live in michaels woods off bigbethel,, i went with the wheelers aal. i tow a 26' travel trailer and it does great. where in hampton are you..?
  6. Nov 19, 2009 at 9:36 AM
    757southpaw
    Jay
    757
    That's good to know b/c I'll be pulling a boat in the future. Do you get any sag when the trailer is attached?
    I live in the Fox Hill area! Do you know of any good mechanics that'd help me or do the lift?
  7. Nov 19, 2009 at 9:39 AM
    CAMZTRD
    steve
    hampton, va
    i do get alittle sag when towing...but im carrying 6000lbs..if you have a spring compressor its a very easy job. i did mine in a half day.
  8. Nov 19, 2009 at 9:54 AM
    757southpaw
    Jay
    757
    No spring compressor!
  9. Nov 19, 2009 at 10:00 AM
    CAMZTRD
    steve
    hampton, va
    you can rent one at autozone or advance for like 25 bucks.
  10. Nov 19, 2009 at 10:09 AM
    757southpaw
    Jay
    757
    Gotcha! Would like to see your Tacoma in person. What do you think?
  11. Nov 19, 2009 at 10:14 AM
    CAMZTRD
    steve
    hampton, va
    pm sent.
  12. Nov 19, 2009 at 11:27 PM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    wheelers claimed you can use the stock u bolts, are you running stock u bolts with the 1.5 aal?
  13. Nov 20, 2009 at 5:10 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    So adding a 1.5 AAL in the rear means you need a 2.5 lift in front?
  14. Nov 20, 2009 at 5:35 AM
    CAMZTRD
    steve
    hampton, va
    yes i using the stock u-bolts...
  15. Nov 20, 2009 at 5:36 AM
    CAMZTRD
    steve
    hampton, va
    if you want it to be level.
  16. Nov 20, 2009 at 9:53 AM
    671taco
    Guam
    twenty-ten rc
    thanks, so it sits right about leveled? have any more side shots?
  17. Nov 20, 2009 at 10:03 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    hey guys, Im thinking of doing the same with my 08 dc. did you have any alignment problems with the 5100s cranked all the way up? and, did u use the diff, drop braket kit or is it not a problem with 2"?
  18. Nov 21, 2009 at 11:13 AM
    757southpaw
    Jay
    757
    I'll let you know if I have the problem. From what I've been reading, the diff drop and the uca's (upper control arms) aren't necessary w/ this lift option. However their are some that are say if you want to do it rite, install new uca's!
  19. Nov 21, 2009 at 11:15 AM
    757southpaw
    Jay
    757
    I'll probably use the stock u-bolts...unless told other wise!
