1.5 toytec block or aal
Discussion in 'Suspension' started by Burgess65, Dec 17, 2012.
  1. Dec 17, 2012 at 11:05 AM
    Burgess65
    Burgess65 [OP] Active Member
    Looking at buying an ome for my 08 prerunner. Have a couple questions, would there be any downsides to getting the 1.5 in block from toytec over the 1.5 inch aal? I am looking for good ride quality and I'm really want to level it out at a full three inches. Also, I was just wanting to confirm that I do not need the differential drop because my prerunner is 4x2. Any responses will be greatly appreciated! Really don't see a whole lot of off-road. Mainly going for looks.
    Thanks!
  2. Dec 17, 2012 at 11:06 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    No diff to drop, haha. AAL is always greater than a block.
  3. Dec 17, 2012 at 11:13 AM
    Burgess65
    Correction, it's a 2inch aal.
  4. Dec 17, 2012 at 11:15 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  5. Dec 17, 2012 at 11:16 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    If just for looks the 1.5 block should be fine. Now it’s not the best way to lift the rear and blocks often contribute to axle wrap issues, but at 1.5 you should be fine and the ride will stay pretty much factory.
    The AAL will stiffen things up a bit, but in terms of rear lift it’s a better approach then the block.
    My opinion, forget both and do an Icon multi AAL and get and improved ride and your 1.5" lift. There are also other options out there which are similar to the Icon AAL packs, I believe Wheelers sells and Multi AAL I hear rides good too.
    Best of luck
  6. Dec 17, 2012 at 11:19 AM
    Burgess65
    Yeah I knew that was a dumb question as soon as I posted..
  7. Dec 17, 2012 at 11:25 AM
    Burgess65
    Yeah. For some reason my phone wasn't showing the 1.5 aal from toytec. I get on my pc and it does. Who knows what the deal was!
  8. Dec 17, 2012 at 11:31 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I agree with most of this, except for recommending a 1.5 block just for looks, a block will deteriorate the quality of your ride, it will promote axle wrap, so if you want to have the look of an extra inch or two WITH deteriorated ride quality, then a block is the way to go. Since the single aal doesn't cost much more, the benefits far outweigh the cost difference. Benefits being increased load capacity, better flexing, etc.
  9. Dec 17, 2012 at 11:34 AM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    the 2" toytec AAL is for the 3 leaf pack, the 1.5" toytec AAL is for the 4 leaf pack
  10. Dec 17, 2012 at 11:39 AM
    Burgess65
    So i should be fine with the 1.5 leaf pack correct? Sorry if these seem like dumb questions. I've been reading a lot about lifts lately and have decided that i want to do it. Also i plan on running the stock rims until i can get new ones, so spacers are going to be needed correct?
  11. Dec 17, 2012 at 11:42 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Only if you change to a wider tire.
  12. Dec 17, 2012 at 11:45 AM
    Saskquatch11
    check your leaf springs to see what you have, 3 or 4 leaf pack. you will not need spacers to run stock wheels unless you go with a wider tire.
  13. Dec 17, 2012 at 12:13 PM
    Burgess65
    Awesome, Thanks!!
  14. Dec 21, 2012 at 12:41 PM
    Denteen
    Denteen Active Member
    Central valley
    2005 4x4 Dcab 5ft bed Silver
    Icon Stage 2 with Rear Resis;ICON 3 leaf AAL installed!
    okay. stupider question. So I lift my '05 4wd Double cab SB 2-2.5", and I WANT the spacers to push the 265 tires out a bit. Not a problem either?? Is that a pretty common thing to do? I'm another "new to lifting" guy...tks D.
  15. Dec 22, 2012 at 8:22 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    Lol no. a block will ride just like stock. but it will promote axle wrap a lot.
  16. Dec 22, 2012 at 10:24 PM
    Bookin
    Bookin Well-Known Member
    I'm running a 1.5" block in the rear. The rear end rides just like stock, as you said. However, the axle wrap issues I had when the suspension was stock have gone away and I no longer experience any axle wrap.
