1.5" TSB AAL or 2" AAL (With 2.5" Up Front)
Discussion in 'Suspension' started by pivey14, Feb 9, 2013.
1.5" AAL or 2" AAL (2.5" Up Front) (Please Read B4 You Vote)
Poll closed Mar 11, 2013.
  1. 1.5" TSB AAL
    3 vote(s)
    25.0%
  2. 2" AAL
    9 vote(s)
    75.0%
  1. Feb 9, 2013 at 9:06 AM
    pivey14
    pivey14 [OP] Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    I will be ordering my lift soon, but I am having to make a tough decision. I will be purchasing 5100's @ .85 with Eibach Coils, which would bring me to 2.5" up front. From what I have read, 1.5" TSB AAL will level me out, but I am worried about it maybe sagging and giving me a "bro lift." I know that the 2" AAL would give me a rake, but I just don't want a "bro lift." Will the 1.5" TSB AAL level me out, and can I even use it if I don't have 4 leafs (currently have 3 leafs)
  2. Feb 10, 2013 at 1:33 PM
    pivey14
    Austin, TX
  3. Feb 11, 2013 at 9:21 AM
    pivey14
    Austin, TX
  4. Feb 12, 2013 at 10:59 AM
    pivey14
    Austin, TX
    Still need convincing
  5. Feb 12, 2013 at 12:06 PM
    Roadliner
    Roadliner Active Member
    Attleboro Ma
    2012 TRD Sport
    I have 5100 ready go in the front and 1.5 AAL for the back. I was planning on setting the 5100 at 1.75, with 1.5 should but me at a good stance. But, I’m now thinking I should get OME 844 springs to add to the front, just for a better ride, which may put me a little front high???
    If you go to 2.5 with the Eibach are you going to have UCA issues? I would like to stay right around 2” in the front and hope not to have any alignment issues.
  6. Feb 13, 2013 at 2:55 PM
    pivey14
    Austin, TX
  7. Feb 13, 2013 at 3:02 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You can use the tsb AAL without the Tsb. I personally would go with the 2" because i like a little rake and stock leaf springs sag if you haul alot of weight in the bed
  8. Feb 13, 2013 at 3:22 PM
    pivey14
    Austin, TX
    I will be carrying a good amount of weight (roughly 150lbs) from time to time. I usually only tow a trailer about once every 3 months. Thanks for the input. I'm probably going to get the 2", but just wanted to hear some more input. Thanks again.
  9. Feb 13, 2013 at 3:25 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    How heavy is the trailer? I personally have dakars with a leaf removed and they are great for hauling/towing. I have heard great things about wheelers 3 leaf AAL. They now offer a HD version which would be ideal for either constant weight in the bed or heavy hauling/ heavy tounge weight
  10. Feb 14, 2013 at 9:16 PM
    pivey14
    Austin, TX
    Not heavy at all; one of those you can throw a lawnmower on. I think I'm gonna pull the trigger on the 2" AAL because it comes in a complete package on toytechlifts.com.
  11. Mar 10, 2013 at 11:14 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    i have the wheelers 3 leaf AAL, with billies set to 2.5" and i like the AAL
