1.5in Lift Shackle from Ebay, Warning
Discussion in '1st Gen. Tacomas (1995-2004)' started by gman2530, Mar 21, 2016.
  1. Mar 21, 2016 at 8:01 PM
    gman2530
    gman2530 [OP] Well-Known Member
    San Diego, Ca.
    04 PreRunner
    I purchased these last week, arrived today with 2 Failures in design making them Un-usable.. This is the item & message I sent out.
    Want others to be advised...
    That is what we do here.. Look out for each other. 1st Geners!
    http://www.ebay.com/itm/131245939526?euid=229af55891f14792a6307ae0038e6b43&cp=1
    New message to: belken.motorsports
    Hello, I received the shackles today. During the install process I encountered two significant failures in the design. First was the width, They would not slide past the leaf bushings, 1/8 inch too narrow . Undetermined to allow that stop me, I did Grind the inside of them so they would slide over, the second issue that could not be overcome was the bottom bolts holes would not line up due to the center piece being too close to the leaf pack end, It bumped up against it not allow the holes to line up... Please advise how i can receive a refund. I have taken pictures if there is any doubt to my honesty or integrity about this matter.
    Respectful,
    Gary Guzman.
  2. Mar 22, 2016 at 8:51 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Personally, I would never get an automotive part from EBAY. You get what you pay for.
    Consider it a $50 lesson learned.
    UBYBC likes this.
  3. Mar 22, 2016 at 10:28 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Yes, one must be very, very careful about buying from ebay sellers. Some products are real deals though. Timing chain/water pump kits comprised of all Toyota parts and at a reasonable cost comes to mind. Others (backup cameras with displays for under $30 come to mind) are not worth considering.
    Same can be said for Amazon (and other sellers') merchandise that is advertised and that does NOT come from Amazon.
    As always, Caveat emptor.
  4. Mar 22, 2016 at 10:41 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    eBay is a marketplace.
    Toyota dealerships sell stuff there, would you not buy from them because "eBay?"
    Or is it just that inexpensive products that come from "Don's eBay Store" might be low quality?
    Nothing wrong with using eBay. If you buy cheap shit, you get cheap shit - regardless of where you buy it.
    devinzz1, UBYBC and ChadsPride like this.
  5. Mar 22, 2016 at 3:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I do find it interesting that the seller is using a picture of the toytec adjustable shackles in their product description images. The only commonality is they are both shackles. o_O
    FWIW, the toytec shackles retail for more than twice what the Belkin/ebay seller is asking for his.
    Dirty Pool likes this.
  6. Mar 22, 2016 at 7:37 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Could cut and weld the stock shackles 3" longer virtually free. If you have a welder that is.
  7. Mar 23, 2016 at 1:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The quality Control person went to the bathroom and those slipped through.
    You were doing Good to you took the grinder to them.
    I have bought lots of Good Parts off both Ebay and Amazon if something is to cheap the price most often reflects the quality
    Go China in another 50 years they might make stuff that works
