1.75" 5100 Install Yesterday...major dilemma with actual ride height
Discussion in 'Suspension' started by Dakota 08, May 18, 2011.
  1. May 18, 2011 at 6:55 AM
    Dakota 08
    Dakota 08 [OP] Well-Known Member
    Portland
    08 Dbl Cab
    I need some help... I'm in somewhat of a panic due to my scheduled alignment tomorrow. Yesterday, I installed a the 1.5" Toytec AAL and the 5100s set at 1.75 and I am way nose high. Higher than I actually wanted to be. Will this settle?? Should I go down to the .85 setting??:confused:
    I only need to make room for 265/75/16s and I do have an ARE canopy w/a rack on the bed.
    Also, and I understand this happens with a compressed spring, but it rides really stiff. Will that improve with an alignment?? How much of it is due to the TRD Off Road springs on my truck??:confused:
    Thanks
  2. May 18, 2011 at 6:57 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    take a pic of the bottom coil support on the shock. sounds like it may be flipped and giving you WAY too much lift.
  3. May 18, 2011 at 7:05 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This ^^^ I bet you put it on upside down.
  4. May 18, 2011 at 7:09 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah X3 you shouldn't be that much higher if any at 1.75 with a 1.5 AAL.
  5. May 18, 2011 at 7:12 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x4, I could tell this was going to be the issue just by reading the thread title.
  6. May 18, 2011 at 7:14 AM
    JLee
    Jerry
    Bay Area NorCal
    Also you can fit 265/75/16's on your truck stock.
  7. May 18, 2011 at 7:16 AM
    KPT
    09 Prerunner
    Is the shock installed with the perch like this:
    If so, it is installed UPSIDE DOWN, and there is nothing holding the c-clip in place. Do not drive the truck. Take the shocks off and fix it.
  8. May 18, 2011 at 7:21 AM
    Dakota 08
    Portland
    08 Dbl Cab
    You guys are all awesome and I feel like a complete jackass!! I did install it upside down. Did I cause damage to anything by doing this??
    Also, my spring seat that came with the shock looks a bit different than the one in the picture. Mine is black and does not have as thick of a top perch.
  9. May 18, 2011 at 7:25 AM
    jhodge83
    SC
    you didnt damage anything by that, but make sure you get it changed quick. like KPT said, there's nothing keeping that C-clip in besides the weight sitting on it.
  10. May 18, 2011 at 7:25 AM
    KPT
    09 Prerunner
    The black spring perch comes on the newer 5100's...nothing to worry about there.
    You probably haven't damaged anything yet, but as I noted, without the spring perch enveloping the c-clip and holding it in place, it could fail and cause a big mess. Don't drive the truck, take everything part and re-assemble correct, and be careful when doing so.
  11. May 18, 2011 at 7:39 AM
    jjbeenken
    jjbeenken Well-Known Member
    Big Daddy Woo Woo
    Arkansas
    2010 Taco double cab (under construction)
    Hertz-Arc Audio-PPI-Image Dynamics-Pioneer F90BT-Icon Coils-AP UCA's-Dakar Springs-300 shot NOS!
    WOW! That could have got nasty. I'm glad people ask questions even if they think they're stupid. That was sketchy just putting those together.
  12. May 18, 2011 at 7:40 AM
    KPT
    09 Prerunner
    I'm glad he thought to ask though. This is a very common mistake.....
  13. May 18, 2011 at 7:46 AM
    jhodge83
    SC
    yup. it happened to eddie when we installed his. he had them put together at a shop and we just installed and didnt know until afterwards. he had them swapped around and reinstalled. no biggie as long as nothing happens before then.
  14. May 18, 2011 at 7:50 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Are the instructions that come with the fronts unclear or do they not come with instructions at all? I'm just curious since it seems to be such a common problem. I cheated and bought mine pre-assembled :eek:
  15. May 18, 2011 at 7:51 AM
    KPT
    09 Prerunner
    I bought mine from DSM and they came with a 1 page diagram
  16. May 18, 2011 at 7:59 AM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    This is TacomaWorld at it's finest. A good reason to be a member here.
  17. May 18, 2011 at 8:46 AM
    Dakota 08
    Portland
    08 Dbl Cab
    I'll admit, mine did come with instructions, and now that I take another look at them, they are clear. But being who I am and getting too excited to get the lift installed, I just wasn't paying enough attention. Thank you again for everyone's help.
    I will also admit that between after the install yesterday and getting to work today, I've probably driven 20 miles with the cups upside down!! I feel very lucky nothing happened.:D
  18. May 18, 2011 at 9:38 AM
    TRDSPORTtaco
    TRDSPORTtaco Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    With the number of people who have accidentally put the spring perch on upside down I think Bilstein should start marking "This side up" on the perch.
  19. May 18, 2011 at 9:46 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I'm curious just how much lift putting it on up-side gave you. To be nose that noticeably nose-high even with the 1.5" aal has to be some lift. No wonder it was riding like shit for being set to 1.75".
  20. May 18, 2011 at 9:48 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Probably one of the smartest things I've heard on this site!
