1.75" bilstein 5100 what tires size will fit ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeff1304, Aug 27, 2009.
  1. Aug 27, 2009 at 1:35 PM
    jeff1304
    jeff1304 [OP] Well-Known Member
    Las vegas
    09 Single Cab 4x4 SR5
    i am looking at tires for my 2009 regular cab 4x4 and wasn't real happy with the choices of tires on the stock setup. what tire size could i fit on there if i put on some bilstein 5100s and raised front up 1.75" ?
  2. Aug 27, 2009 at 1:45 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    275x65x16 max. Might even have some rubbage then. 265x65x16 is the max you can have at stock height.
  3. Aug 27, 2009 at 1:58 PM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    max at stock height should be:
    265/70/17
    265/75/16
  4. Aug 27, 2009 at 2:01 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Wrong.
    Right.
  5. Aug 27, 2009 at 2:01 PM
    jeff1304
    Las vegas
    thats what i thought. so was the second post correct on what size i can use with the 1.75" lift in the front ?
  6. Aug 27, 2009 at 2:05 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    The bilsteins aren't going to change what size tire you can put on. The top and bottom of suspension travel will be the same as before.
    I put 265/75/16s on my stock 4x4 and after removing the mud flaps had no rubbing issues.
  7. Aug 27, 2009 at 2:07 PM
    jeff1304
    Las vegas
    so the lift you get out of the bilsteins is not a solid lift :confused: so if i wanted bigger tires i would have to go out and get a full blown lift kit ?
  8. Aug 27, 2009 at 2:08 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    x2
  9. Aug 27, 2009 at 2:09 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    I have this size and never had any rubbing
  10. Aug 27, 2009 at 2:09 PM
    drew02a
    San Antonio, TX
    It depends on how much bigger you want to go. What size are you shooting for?
  11. Aug 27, 2009 at 2:11 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    well 1.75 inches is not a big lift by any means you would be lucky to get some bigger than stock tires in there.
    It is possible to put 285/70/17 and 285/75/16s on your truck without a lift as long as you have wheel spacers to keep from rubbing on the uca's
  12. Aug 27, 2009 at 2:14 PM
    drew02a
    San Antonio, TX
    Those tires it will also rub the body mounts and the inside of the wheel well if you do any offroading and get anywhere near full articulation.
  13. Aug 27, 2009 at 2:15 PM
    drew02a
    San Antonio, TX
    It looks like you have a regular cab and therefor the 2.7L engine. If that is indeed the case I wouldn't go any bigger than 265/75/16 unless you plan to re-gear. Even putting those tires on will give you a noticeable power decrease.
  14. Aug 27, 2009 at 2:16 PM
    jeff1304
    Las vegas
    i would like to fit 285s on it. but am i looking at a combination of the bilsteins and wheel spacers for it ?
  15. Aug 27, 2009 at 2:16 PM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    I've got 2.5" with the bilsteins and run 285/75/16 with ZERO rubbing issues. I do also have FJ wheels so that might make a difference.
  16. Aug 27, 2009 at 2:16 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Whoops. Hit the 6 instead of the 7. My bad.
  17. Aug 27, 2009 at 2:17 PM
    drew02a
    San Antonio, TX
    Do you disconnect your swaybar when you go off pavement?
  18. Aug 27, 2009 at 2:18 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    johnw's truck 285/70/17 stock hight claims the only rubbing he has is on the uca's
    "i have said this in so many other threads but. I have 285/70/17 tires no lift 1/4inch wheel spacer and only rubs the UCA AT FULL TURN. i dont usually make full turns and even then if i do its minor rubbin"
  19. Aug 27, 2009 at 2:19 PM
    jeff1304
    Las vegas
    a 3% increase in tire size would influence my engine power that much ? but my target would be 265/75/16
  20. Aug 27, 2009 at 2:20 PM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    No I keep everything hooked up but my truck isn't an offroad machine either. I hunt, fish, and camp so that's the most offroad it sees. I'm VERY happy with the setup I have. I ran 265's for about 2 weeks and had to step up to 285's. It's the perfect combo IMO.
