1.75" bilstein 5100 what tires size will fit ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeff1304, Aug 27, 2009.
  1. Aug 27, 2009 at 2:22 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Can't you read your own quote? He says:
    "Said rubbage seems severe enough to warrant cutting a piece of the frame and rewelding....Not to mention the obvious mudflap removal and wheel well trimmage."
    The timming he's talking about means it's rubbing more than the control arm. All this is beside the point, because like I said earlier, it is inadvisable to put tires bigger than 265/75/16 or 265/70/17 on a Tacoma with a 2.7L engine unless you plan to re-gear.
  2. Aug 27, 2009 at 2:23 PM
    wmflyfisher
    wmflyfisher Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    You would notice some but I wouldn't consider it a deal breaker. If I'm not mistaken I think the 4cyls in the 05+ models might have a tad more power that the previous. Again, I could be wrong though.
  3. Aug 27, 2009 at 2:24 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Anyone running 285/75R/16's "without rubbing" is not off roading unless they have a 3+ inch lift. :rolleyes:
  4. Aug 27, 2009 at 2:27 PM
    jeff1304
    jeff1304 [OP] Well-Known Member
    Las vegas
    09 Single Cab 4x4 SR5
    is there anything special i need to do to use 265/75/R16 ?
  5. Aug 27, 2009 at 2:28 PM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    Not disagreeing with you at all but this is subjective. Some people don't mind the power loss and others would rather regear. I ran 255/85's (33x10.5) on my 01 with the 4cyl and it was fine for me. You are right too though. It can be lagging at times.
    Jeff, you probably won't be able to tell if you like it or not until you try it. Just depends on what YOU want.
  6. Aug 27, 2009 at 2:29 PM
    drew02a
    San Antonio, TX
    I assure you the power loss is not negligible. If you look at my profile right over there <= you'll see I have a 2nd gen with a 2.7L engine. I know what I'm talking about. The change to 265/75/16 was significant enough power loss for me. I can't imagine going any bigger.
  7. Aug 27, 2009 at 2:31 PM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    You "should" be totally fine going this route. Probably the safest if you plan on wheeling it any.
  8. Aug 27, 2009 at 2:32 PM
    drew02a
    San Antonio, TX
    Agree'd 265/75/16 will be totally fine on your truck as is.
  9. Aug 27, 2009 at 2:39 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    I would not go bigger, and I am looking at weights of the tire options in the 265/75R/16 size. :cool:
  10. Aug 27, 2009 at 2:41 PM
    drew02a
    San Antonio, TX
    The reason most people use the 5100s is to level their truck.
  11. Aug 27, 2009 at 2:48 PM
    jeff1304
    Las vegas
    but i heard some of the 265/75/r16s would rub
  12. Aug 27, 2009 at 2:54 PM
    drew02a
    San Antonio, TX
    They rub the mud flap just barely, other than that, there's no rubbing at all. I've wheeled hard with mine and have had no problems. :D
  13. Aug 27, 2009 at 2:55 PM
    drew02a
    San Antonio, TX
    I removed my mud flaps, but it some states they're required.
  14. Aug 27, 2009 at 2:57 PM
    sdel82
    sdel82 Active Member
    Northeast
    09 dbl cab
    I just put 265/70/17's on and was worried about rubbing because they looked so much bigger than the oem 245/75/16. What a difference! Way better look, way better ride. They came off a 2010 FJ cruiser. I swapped out rims also fyi.
  15. Aug 27, 2009 at 3:40 PM
    #35
    jeff1304
    Las vegas
    ok another thing what tires do all of you suggest that is pinned for studs in 265/75 ?
  16. Aug 27, 2009 at 3:47 PM
    #36
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    The Goodyear Wrangler Duratracs are pinned for studs.
  17. Aug 27, 2009 at 3:54 PM
    #37
    jeff1304
    Las vegas
    forgot to add that these will be used at snow/ mud tires preferably. and i dont need anything like load range e i would prefer load range c. was looking at firetsone destination mt's
  18. Aug 27, 2009 at 4:12 PM
    #38
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    Destination mt's are pretty good. Not sure what your budget is but I find that BFG's are the best tire that I have ever had. Yes, they are pricey but you pay for what you get in most cases. I've had BFG's in all and mud terrain. If you rotate them regular and check the psi they will last a good while and ride good too.
    Another option are the Cooper STT's. I had these in 285's and they rode nice. Were a bit cheaper that the BFG's too.
    Right now you can save 10% through Bing.com if you purchase on ebay. Let me know if you need more info on how to do this. I bought my Cooper's last year through Bing and Ebay and got the whole set for $520 shipped!
    #38
  19. Aug 27, 2009 at 4:29 PM
    #39
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Heres a picture of my 5100s up front set to 2.5 w/ a 1.5 AAL in the rear. SAW 2.0 shocks in the rear. 265/75-R16 Yokohama Geolandar AT-S on stock steelies.
    I have only experiences the SLIGHTEST amount of rubbing on the front mud flaps (before I decided to take them all off). To be honest, I've only felt them rub twice in about a years time.
    EDIT: FWIW, I ran the 256/75s with stock suspension for about four months. No rubbing issues there either.
  20. Aug 27, 2009 at 4:40 PM
    #40
    SC4333
    Grant
    FL
    I couldn't agree more. From first hand experience, anything larger than 265/75-R16 with the 2.7 engine will most definitely warrant re-gearing. Sure some people will say it is not necessary, and it is not, although you will be putting one hell of a strain on that little engine. Not to mention it will be slow as a turd when you want it to get up and go.
    The 265/75-R16s I'm running weight in at 53 pounds a piece. That is the tire alone, not including the heavy steel wheel. This alone is enough to let you feel a difference in the seat of your pants. Take into account the increased diameter changing your final drive ratio and you have a recipe for re-gearing if you desire to go any larger with the 2.7 engine.
