1" block lift on 2017 Off Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maxrider, Dec 20, 2016.
  1. Dec 20, 2016 at 3:09 PM
    maxrider
    maxrider [OP] Well-Known Member
    2017 TRD OFF ROAD
    If I put the toytech 1" block kit on the rear of my truck will I also need the 5100's on the rear, or will the stock shocks be long enough?
  2. Dec 20, 2016 at 3:10 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Why?
    Taco Addiction likes this.
  3. Dec 20, 2016 at 3:12 PM
    maxrider
    2017 TRD OFF ROAD
    I put the 5100's on the front in the third clip and the front is about a 1/2" higher than the rear now. Thought I would just add an 1" to the rear now
  4. Dec 20, 2016 at 3:14 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You're fine.
  5. Dec 20, 2016 at 4:25 PM
    maxrider
    2017 TRD OFF ROAD
    So the rear shocks that I have will work?
  6. Dec 20, 2016 at 4:30 PM
    T4RFTMFW
    Yes.
    maxrider[OP] likes this.
  7. Dec 20, 2016 at 5:02 PM
    securekey
    securekey Well-Known Member
    2018 TRD Off-Road DCSB - Blazing Blue
    They will work but the 5100s would allow more travel ... if you aren't going off road it shouldn't make any difference imo
  8. Dec 20, 2016 at 5:04 PM
    T4RFTMFW
    What's the extended length of the OEM rear shocks compared to the OEM replacement 5100s?
  9. Dec 20, 2016 at 5:08 PM
    Clearwater Bill
    Billy
    Largo Florida
    Another option is to lower the front clip and leave the rear alone. Not only would you cure the reverse rake, you'd unload a bit of the preload on the front springs, improving ride, spring travel while reducing the risk of coil bind.
    Contrary to all the thinking around here, a little rake is actually a good thing.
    'Level' is only for looks.
    daddy_o, JoeCOVA and securekey like this.
  10. Dec 20, 2016 at 5:15 PM
    maxrider
    2017 TRD OFF ROAD
    Yea I kicked that around also hate to take the damn thing back apart. Thought I would add a 1" block to the rear and get a small amount of take with a little more lift.
    securekey likes this.
