1" block vs 1.5" aal + questions, need advice
Discussion in 'Suspension' started by dieselstaco, Nov 19, 2010.
  1. Nov 19, 2010 at 1:20 PM
    dieselstaco
    dieselstaco [OP] Well-Known Member
    Northern Nevada
    2012 Tundra Rock Warrior
    so i'm having my lift parts put in on monday and need some advice on what exactly i should do.
    I've got the 5100's for all 4 corners, eibach springs and 1.5" aal ( and TSB has already been done). the 5100's go in for sure along with the eibach's. what i can't decide is whether to go with:
    5100's @ 0 with no block or aal
    5100's @ 0 with 1" block
    5100's @ .85 with 1.5" aal
    right now it's 37.5" from ground thru center cap in the rear and 35.5" in the front.
    After reading the trouble some guys have had getting the alignment right with the springs and 5100's @ .85, i'm thinking I might go with them set @ 0.
    What do you all think?
  2. Nov 19, 2010 at 1:32 PM
    dieselstaco
    Northern Nevada
    do i need a front diff drop with that set up to get alignment to spec?
  3. Nov 20, 2010 at 8:40 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    I just did a Toytec 1.5" AAL and 5100's set at 1.75. I wound up with 24 1/2" Rear and 22" Front measured from the center cap. It just went on last night, so no time for it to settle yet. The rake is not much more than factory. I'm fine with the difference since my reason for putting the AAL on was to keep it from sagging when I tow my travel trailer. I am thinking it will wind up just about level now with the RV on the back.
  4. Nov 20, 2010 at 8:42 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    No you don't need a diff drop with that little amoumt of lift
