1" Block, will i have any problems?
Discussion in 'Suspension' started by Cogge89, Aug 22, 2010.
  1. Aug 22, 2010 at 1:13 PM
    Cogge89
    Cogge89 [OP] Well-Known Member
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Pioneer AVH-P4100DVD, Kicker ZX400.1 Amp, Kicker CVT 10" Sub. Light Racing UCAs, Front OME Shocks with 885x Coils, Rear OME Shocks with Dakar Leaf Pack, Engine Cover Paint Job, 265/70/17 Duratracs.
    I had my 4x 5100s installed, and my TSB leaf has been in for about a year. Most people can run 1.75" it seems, however I could not. At the .85" setting, its pretty close to level. I would still like to set them at 1.75", so i did some measuring. About 1" in the rear will be perfect for me. Do you guys think I'll have any problems with a 1" block? I do zero off roading, but if it will cause problems, I can go a different route.
  2. Aug 22, 2010 at 1:31 PM
    LuckeyTRD
    LuckeyTRD rIDIN wHEELIEz!!
    Cole
    Evans, GA
    2010 PreRunner ALL TERRAIN
    BHLM, Blacked out tails, window tint 5%, tinted windshield , 8000k hids hi/lo and fogs. Black side badges, debadged tailgate, camburg 1.25" uniball UCA's, Camburg 4" spindles, ext. brake lines, Fox remote resi coilovers. Fox 2.0 Pro series rear piggybacks, 3" Allpro Leaf pack, OEM roof rack, Brush guard. Custom TRD allterrain decals. UWS low profile black toolbox
    blocks in the rear really wont hurt especially that small of a block, since u dont offroad i dont see why not.
  3. Aug 23, 2010 at 9:08 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    I see your truck sit level . If you add 1" block to the rear then you should set the front at 2.5" , otherwise your back is way too high if set 1.75" .
    I got same set up as your thinking to do your and I loved it . no problem at all.
  4. Aug 23, 2010 at 9:38 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    should be fine
  5. Aug 23, 2010 at 10:02 AM
    Cogge89
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    I've only got like 9/16 difference between front and rear at .85 setting so I think it will be nose high with another 3/4 in the front without anything else in the back
  6. Aug 23, 2010 at 10:10 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    I don't see anything wrong with a 1" block if you dont offroad. Another option would be extended shackles.
  7. Aug 23, 2010 at 10:15 AM
    Cogge89
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Yeah? I can have a 1" leaf built too. Just unsure of the price as of right now. Ill go with that unless the price is bad
  8. Aug 23, 2010 at 10:41 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I really doubt that anyone would notice any ill effects from blocks unless maybe they're going to the local drag strip. I've been wheeling pretty hard on 3"ers for about 15 years. Just stay away from aluminum, cheap kits & keep your u-bolts tight. I have a nice block/u-bolt setup that you'll actually be able to trust under there. For 1" I have 2 different style blocks you can choose from. Either ones that will bolt to your leaf pack and come with a longer leaf pin/bolt, or the more common style that doesn't bolt to the pack. The bolt on style runs $38.95 for the pair, and the standard style blocks are $56.95.
    The u-bolts are top quality, I have them made at a spring shop. There are 2 different diameter options, 1/2" grade 5 or fat 9/16" grade 8. They all use high nuts and extra thick washers. The more common 1/2"ers run $55.95 for the set. They're as good as u-bolt gets. Shipping is $16.80 for the entire kit. This price of this kit is what you'll spend for a bullet proof block/u-bolt kit, unlike cheap grade 3 junk from the local parts store. Your u-bolts will obviously be the square style, and made to fit the 1" block, so there won't be a ton of threads to chop.
  9. Aug 23, 2010 at 10:52 AM
    Cogge89
    Justin
    Saint John, NB
    09 Tacoma TRD Sport
    Wow thanks. Ill msg you later about them. I'm on the highway on my Blackberry right now haha
  10. Aug 23, 2010 at 10:53 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    haha, better pull over to read that post then. :)
  11. Aug 31, 2010 at 3:26 PM
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    2010 - DC Pre-Runner TRD sport - I have 5100's front set at 2.5 - rear TSB with 1" block - Great set up. Love the look of it - awesome!
  12. Aug 31, 2010 at 3:42 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    :anonymous: I have a block on mine and i go offroading every time i have chance.
    No problems :D
