1" blocks plus AAL for axle sag.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaulVthe3, Jan 17, 2010.
  1. Jan 17, 2010 at 6:19 PM
    PaulVthe3
    PaulVthe3 [OP] Well-Known Member
    Ive got 5100's all the way around on my 2009 DC v6 4x4. The fronts are set to 2.5 or all the way up, Ive got an AAL in the rear along with 5100's. My problem is that the rear seems like it need an extra bit of lift. Can I use a 1"or 2" block with an AAL? Will I have to extend the brake lines? Has anyone else done this? Thanks.
  2. Jan 18, 2010 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you do any offroading or towing/hauling?
    Blocks are generally a bad idea especially while offroading. I've offroaded with people who have blocks.....the torque load transfers into the blocks and they crack/brake and can literally FLY out from under the truck. I knew a guy who go hit in the leg with a piece of a broken block before.
    If you're strictly driving around town without any torque on the axle, you can probably get away with it. But.....while offroading and towing - I wouldn't put blocks in.
    Buy yourself a totally new leaf pak that'll give you 2.5" of lift.
  3. Jan 18, 2010 at 7:57 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    You have other options like a new higher AAL or shackles all the way to a custom leaf pack. I just wouldn't do blocks. I am sure 1" is ok for temporary use only.
  4. Jan 18, 2010 at 6:09 PM
    PaulVthe3
    Thanks for the replies. I do little offroading, just at my property, and I do load my quad in the back of the truck. Who has good deals on a higher AAL or shackles for my truck?
  5. Jan 19, 2010 at 5:38 AM
    sirsaechao
    Tim
    Commifornia
    What AAL do you already have in?
  6. Jan 19, 2010 at 5:58 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Check out the toytech AAL or the OME Dakar leaf pack.
  7. Jan 19, 2010 at 6:25 AM
    Janster
    Jandy
    Lancaster, PA
    The AAL you already have in there - how long have you had it? Do you haul your quad often?
    AAL's can sag over time. If you put another AAL in there, it'll sag also (over time) especially if you're hauling the quad often.
    You should look into getting some helper springs to help prevent the sag (maybe) over time.
  8. Jan 19, 2010 at 4:40 PM
    PaulVthe3
    its a fabtech AAL that I got from DSM.Ive had it for about 6 months.
