1" body lift question
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomatt602, Sep 4, 2015.
  1. Sep 4, 2015 at 2:44 PM
    tacomatt602
    tacomatt602 [OP] Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    5-lugger here. So I'm gonna go ahead and buy Daystar's 1" body lift kit sometime in the next couple weeks and I just had a quick question. I'm still doing research but I thought I'd ask here anyway. I've read that some people had to buy steering shaft extensions and possibly other things to compensate for their body lifts. If I'm only going up 1", would I also need to buy that same stuff? Different stuff? Hopefully no extra stuff at all?
  2. Sep 4, 2015 at 2:49 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Body lift is a fair amount of work. Have you looked at FatBob's suspension lift for five lugs?
  3. Sep 4, 2015 at 4:28 PM
    tacomatt602
    Phoenix, AZ
    Just checked it out. I have the 1.5" spacers installed already and it looks like the other option for front lift on FatBob's are the 3" lift spindles. I'm just not looking for such a drastic (to me) lift.
  4. Sep 4, 2015 at 7:06 PM
    tacomatt602
    Phoenix, AZ
    Looks to me like I won't need a steering shaft extension with just a 1" BL. Can anyone confirm?
  5. Sep 4, 2015 at 7:08 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I seriously doubt it.
  6. Sep 4, 2015 at 7:10 PM
    tacomatt602
    Phoenix, AZ
    N that's the only mod someone would need to make with a body lift right? Everything else should be ok?
    <-- n00b on body lifts
  7. Sep 5, 2015 at 7:55 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The other issue might be the radiator/shroud. These 1" kits should come with adapters to lower the radiator 1". Otherwise the shroud will impact the fan. Without the adapters, removing (or modifying) the shroud is an option, but that could lead to overheating.
  8. Sep 6, 2015 at 11:26 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Body lifts in general are pretty meh IMO. They can incur a whole handful of other issues, especially on older vehicles. Granted 1 inch is tame and mostly harmless, I would look into more suspension lift. There are a handful of options and they price at roughly the same. I put a 3 inch body lift on my first vehicle (88 pickup) and regretted it every day I'd owned it afterwards.
    If you're sold on the body lift, there isn't much a 1 inch body lift could mess up in theory and you shouldn't need to adjust much except maybe the radiator like tan said. But as one finally warning, just consider what you're actually doing with a body lift. You're separating a handful of old wires and tubes that are in places you didn't even know existed on your truck. Good luck!
    DustStorm4x4 likes this.
