1" body lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Apr 20, 2020.
  1. Apr 20, 2020 at 2:34 PM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    Ordered a 1" bodylift from Bilstein lifts. I have decided to install the bodylift for tire clearance issues so I'm not concerned too much about options on bodylifts in general.
    I saw that a member on this forum only installed the cab spacers and not the bed spacers. Is this bad for anything on the truck? I don't see how it could be other than the slight chance it messes with the flexing of the frame due to higher center of gravity in the front and lower in the rear, however, that shouldn't be a problem because when you load up the bed the center of gravity changes unproportionally as well.
  2. Apr 20, 2020 at 2:41 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    There is a thread floating around with a picture of the cab lifted before the bed spacers were put in. It looks bad. You’ll want the bed lifted too. -Just saying.
    Blackbeard83 and Mully like this.
  3. Apr 20, 2020 at 2:42 PM
    Dr. Emmett Brown
    Yes I saw that thread. It didn't look terrible to me but I know what you mean. I'll probably end up installing all of them.
  4. Apr 20, 2020 at 2:45 PM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    :thumbsup:
    stun gun and Taco-Obsessed like this.
  5. Apr 20, 2020 at 2:46 PM
    Dr. Emmett Brown
    Other question is about the steering coupling. That needs to be loosened prior to lifting? What about radiator supports?
  6. Apr 20, 2020 at 2:47 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    What tire clearance issue are you trying to solve? I.e. where does the tire rub?
  7. Apr 20, 2020 at 2:49 PM
    Dr. Emmett Brown
    Wheel well. Everywhere. Caster set at 3* CMC done aggressively.
    Rockefelluh[QUOTED] likes this.
  8. Apr 20, 2020 at 2:50 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Correct on the steering coupling. Your kit should include some brackets for the radiator.
    You will probably not be able to do a topper without lifting the bed, but otherwise shouldn't be too many ill effects
  9. Apr 20, 2020 at 2:50 PM
    Dr. Emmett Brown
    Right on. Thanks for the info. Do you know if the gas neck needs to be unbolted before lift as well?
  10. Apr 20, 2020 at 2:53 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Also, yes. There should be a 1 inch plastic spacer for that in your kit as well.
  11. Apr 20, 2020 at 2:54 PM
    Dr. Emmett Brown
    I'm assuming you put one of these kits on your truck?
  12. Apr 20, 2020 at 3:00 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Yes, on my 2nd gen. Should be identical to your truck...even looks like the same part number / description. If you do end up lifting the bed, make sure you pay attention to the size of the holes in the pucks between the radiator and the rear. The rear has the same sized pucks as the radiator supports, but the holes are different sizes for the bolts that go through them. Ask me how I know :anonymous:
    From an effort standpoint, have you considered wheel spacers versus a body lift?
  13. Apr 20, 2020 at 3:04 PM
    Dr. Emmett Brown
    Haha much appreciated!
    I still need to do small wheel spacers to get my tires away from my JBA UCAs. I have 295/70/17 muds on 17x8 with 0 offset. I tried 1.25" wheel spacers and I was going to have to relocate the cab mount. It wouldn't even let me full lock at all.
    I rub inside all over the wheel liners under compression while turning. It was between removing wheel liners completely, DB lift, or body lift. I'm choosing the body lift because it's only 1" which shouldn't do much with stressing components.
  14. Apr 20, 2020 at 3:11 PM
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    :thumbsup: wanted to make sure you had looked into less challenging options. Your truck's newer than mine so hopefully rust isn't as much of a problem. Those cab and bet bolts were a bitch and a half. HIGHLY recommend getting a friend to help with it, especially for tightening everything down. Can't be inside the truck and underneath it at the same time.
  15. Apr 20, 2020 at 3:37 PM
    Roskolokes
    Roskolokes Active Member
    How much does it cost to do a body lift?
  16. Apr 20, 2020 at 7:22 PM
    Dr. Emmett Brown
    The kit was $190 and I'm doing the install. But my buddy Heineken will be there to assist me so I'm pretty confident.
  17. Apr 20, 2020 at 7:23 PM
    Dr. Emmett Brown
    That's what I was hoping. Might as well get the truck how I want it while it's young and easier to deal with.
  18. Apr 20, 2020 at 8:17 PM
    Dr. Emmett Brown
    Didn't see your comment till now because I ignored you a while ago, but did you get banned? What's that strike through your username for?
    Anyways, I don't understand your comment? You're always welcome to come to Hawaii and wheel with us, if you're free.
    Aloha, my braddah.
