1 Bored Clerk's Garage Built Camper
Discussion in 'Other Builds' started by 1 Bored Clerk, Oct 24, 2016.
  1. Aug 29, 2019 at 8:35 AM
    #1441
    Wild Crow
    Wild Crow Well-Known Member
    James
    Anywhere is home
    2014 Baja
    It looks awesome! Congraduations!
    1 Bored Clerk[OP] likes this.
  2. Aug 29, 2019 at 8:42 AM
    #1442
    1 Bored Clerk
    1 Bored Clerk [OP] Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    Thanks! It definitely sticks out in the parking lot at work. :rofl:
    Drainbung likes this.
  3. Aug 29, 2019 at 8:48 AM
    #1443
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  4. Aug 29, 2019 at 9:14 AM
    #1444
    Moto_dj
    Moto_dj Well-Known Member
    Michigan
    2012 White Tacoma TRD
    That thing looks great! Awesome craftsmanship. Any idea how much the camper shell weighs?
  5. Aug 29, 2019 at 9:23 AM
    #1445
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Thanks! I’m guessing it’s close to 500lbs as it sits.
  6. Aug 29, 2019 at 9:33 PM
    #1446
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Wired up my 12v socket to the aux fuse block with the LVD. It works but cuts out within about 30 seconds of shutting the engine down. I’m not positive but I think my battery is just holding above the cutoff point for the LVD. The refrigerator draws enough power on initial startup and cooling that it pulls the battery quickly below the cutoff point. The battery has always started the truck with authority but it may be on the ragged edge of healthy. I have a group 31 AGM (have had it for probably 4 years now)...a group size that seems to be known to be hard to properly maintain. Anyway, I’ll likely go straight to dual batteries with something like a redarc manager 30 to handle the business of the batteries. I’ll probably also step down to a standard group battery for the stock location and use a group 35 for the aux battery. The group 31 is big and makes getting at the oil filter a little fussy.
    Will be nice to solve the electrical problem but it’s a spendy problem to solve. I’ll take my time and put it all together correctly...over a few months I would bet. Maybe sooner?
    113tac and loyaltothetaco like this.
  7. Aug 29, 2019 at 9:35 PM
    #1447
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
  8. Aug 29, 2019 at 10:05 PM
    #1448
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Pop some fireworks.
  9. Aug 30, 2019 at 8:11 AM
    #1449
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    I just pulled the trigger on an off grid engineering aux battery tray for the passenger side fender area. I also ordered up a factory OEM battery tray and hold down to replace my group 31 tray from PelfreyBilt. I’m going to go back to basic lead acid batteries: group 27f for the main battery and group 35 for the aux battery. I can always upgrade to AGMs of the same size in the future if I feel like I need to. For the cost of AGM vs lead acid though...maybe not worth it for me. We’ll see.
    Drainbung, 113tac and Martyinco like this.
  10. Aug 30, 2019 at 8:32 AM
    #1450
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    I have one of Matt's early dual battery kits in my Tacoma. Same side system with the Blue Sea Systems ML-ACR. It's been in there for three years now and I am very happy with it.
  11. Aug 30, 2019 at 8:37 AM
    #1451
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Nice! It looked like the best aux battery tray for my truck. Looked really well made and well thought out. Nice that it takes up a completely unused area under the hood. What two batteries are you running and have you had any issues keeping them charged? What accessories are you running and how often? Just curious...no need for a novel or anything. :thumbsup:
  12. Aug 30, 2019 at 9:00 AM
    #1452
    PNW/TRD Steve
    WA
    2012 DCSB TRD
    No problem. Odyssey AGMs. I have to confess, no camp run accessories as of yet. Only led lighting, an ARB twin compressor, and a 12k winch. A refrigerator will go in at some point but as far as upcoming dual battery type things; probably some area lighting, constant power to bed and Tepui tent via existing sp8100.
    Original plans included on board hot water system with pumps.
  13. Aug 30, 2019 at 9:03 AM
    #1453
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Great progress man! I’ve been following you since you started the DIY bumper. Glad to it finally on the truck.
    On your batteries, I would swap the duty of each battery. Your current start battery would be the house and vice versa. This is so you can have the smaller batter just worry about starting the truck and the other with more capacity can power the camper.
  14. Aug 30, 2019 at 7:23 PM
    #1454
    Martyinco
    Martyinco Well-Known Member
    Wait, so now that’s it’s on the truck, what are we all going to look forward too :rofl::rofl:
  15. Aug 30, 2019 at 7:29 PM
    #1455
    El Duderino
    Jeremy
    HI->PNW
    Interior design and adventures
  16. Aug 30, 2019 at 7:30 PM
    #1456
    Martyinco
    :yes:
  17. Aug 30, 2019 at 7:31 PM
    #1457
    El Duderino
    Jeremy
    HI->PNW
    Just when you think you’re out
  18. Aug 30, 2019 at 7:44 PM
    #1458
    Martyinco
    He reels you right back in :ballchain:
  19. Aug 30, 2019 at 8:31 PM
    #1459
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Electrical, rear view camera, awning, roof rack, surf rack, new sliders, interior, solar?, kitchen box buildout, and a pile of other stuff I’m sure. You’ll be stuck with me for quite some time!
  20. Aug 30, 2019 at 8:39 PM
    #1460
    Martyinco
    :cheers:
    I’m here for the old school camper curtains :rofl:
