1-gen shutter when breaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by offset442, Dec 12, 2008.
  1. Dec 12, 2008 at 7:45 AM
    offset442
    offset442 [OP] Member
    I have been noticing a problem what I apply the brakes on my truck, i get a shtter in the right front, I took a quick look this morning and noticed that the pads where wearing at a angle instead of square plumb, anyone ever have this problem? I trying to figure out what causes it so i fix it
  2. Dec 12, 2008 at 8:01 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds to me like you have a sticking or faulty caliper. you need to take the brakes apart, and see whats causing the caliper to do this. you may be able to get a rebuilt caliper at autozone pretty cheap and install it. also, you will need new brake pads, and need to turn your rotors when adding the new pads.
  3. Dec 12, 2008 at 8:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Like tacomaman said.... Since there are two pistons in there, one of the pistons could be stuck open.
    I would get a rebuilt caliper for the bad side. Have both rotors checked for warpage and have them both turned. A new set of brake pads for both.
  4. Dec 12, 2008 at 11:41 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :thumbsup:
  5. Oct 13, 2009 at 8:17 PM
    Carone
    Carone Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    I know this post is old. but i did a search and i think i have the same issue, is this common.
    I have a shutter only when coming to a complete stop and only like the first 3 times and then i cant make it do it again until the car sits off for a while
  6. Oct 13, 2009 at 8:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    whens the last time the brakes were done? sounds like maybe a rotor could be warped a little....if the calipers are good.
  7. Oct 13, 2009 at 8:22 PM
    Carone
    NOR CAL
    Look at my Build
    nah. rotor you feel more at high speeds.
    and i took a peek at the pads there at about 5mm. but i couldnt really see if there are wearing at an angle
  8. Oct 13, 2009 at 8:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    maybe for the most part, but when the old rotors were warped on my truck....you felt them while slowing down no matter what speed you were going.
  9. Oct 13, 2009 at 8:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    best bet is to take the wheels off and pull the pads out and check for evenness that way.............you can see if the piston boots are torn that way also.
