1 gen Tacoma mid travel.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Patrickaudish, Feb 25, 2021.
  1. Feb 26, 2021 at 11:48 AM
    #41
    eon_blue
    Azusa, CA
  2. Feb 26, 2021 at 11:49 AM
    #42
    Kwikvette
    Fresno County
    4 run, 2 don't
    eon_blue[QUOTED] likes this.
  3. Feb 26, 2021 at 12:19 PM
    #43
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I'm running 600lbs springs on my 4cylinder at 12 and 14 threads showing and cant feel a speed bump at 30mph. But then again I do have a bumper that might be making a difference. I think id go with 550s if no extra weight. @Allex95 also this https://www.crawlpedia.com/spring_rate_calculator.htm
  4. Feb 26, 2021 at 12:20 PM
    #44
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Going with a steel bumper next week so not 550s lol I rocking 650s with the toytecs and they were fine. I swear it might be just the shorter length of the shock it feels like it can’t extend anymore which is mostly likely preload
  5. Feb 26, 2021 at 12:20 PM
    #45
    Allex95
    allex
    How much lift is that for 12 threads?
  6. Feb 26, 2021 at 12:21 PM
    #46
    Kwikvette
    Fresno County
    4 run, 2 don't
    The shorter length of the shock compared to the Toytec shocks is negligible, especially in the situation you're describing.
  7. Feb 26, 2021 at 12:22 PM
    #47
    eon_blue
    Azusa, CA
    I bet it's just the preload, lessen it down some and let us know how that works out.
    Tour991 likes this.
  8. Feb 26, 2021 at 12:25 PM
    #48
    Allex95
    allex
    Shall do. Yea the shafts are pitted or anything. Its a truck anyways ain’t gonna be car
  9. Feb 26, 2021 at 12:27 PM
    #49
    Kwikvette
    Fresno County
    4 run, 2 don't
    Told him that before, he didn't listen :rofl:
    Tour991 and eon_blue[QUOTED] like this.
  10. Feb 26, 2021 at 12:28 PM
    #50
    Allex95
    allex
    I did listen dammit :rofl: I even called king and they said yea come down we can change that
  11. Feb 26, 2021 at 12:29 PM
    #51
    eon_blue
    Azusa, CA
    You don't have to go to King for that, you can lessen the preload using the big punch that comes with the Kings. Don't even need to jack up the truck or take them off.
    Just loosen the collar with an Allen wrench, stick the punch in the adjustment holes and crank it. Takes a little muscle but it's doable
  12. Feb 26, 2021 at 12:29 PM
    #52
    Tour991
    James
    South Reno/Tahoe
    I think i am at 2 inches. My cv angels are still garbage even with the 1 inch diff drop.
    eon_blue likes this.
  13. Feb 26, 2021 at 12:31 PM
    #53
    eon_blue
    Azusa, CA
    Yup, that's why I'm at like 1.5" lift on mine now. Even with a diff drop (useless junk imo), I was ruining boots at even 2" of lift. I don't know how people rock over 2" lift on here unless they just never talk about their CV boots tearing all the time lol
    Or they have those new fancy high angle CVs
    Kwikvette and Tour991[QUOTED] like this.
  14. Feb 26, 2021 at 12:31 PM
    #54
    Allex95
    allex
    I was told that by the measurements I gave them it’s way to much preload to do it by the collar.
  15. Feb 26, 2021 at 12:32 PM
    #55
    eon_blue
    Azusa, CA
    that's odd....I don't know how else you'd adjust preload than by loosening the collar and turning it, but if anyone can do it right its King themselves.
  16. Feb 26, 2021 at 12:33 PM
    #56
    Allex95
    allex
    They said it’s to much if I did it without compressing the coil I would either break the tool or mess the shock up. There not charging me anyways to bring it down so
  17. Feb 26, 2021 at 12:34 PM
    #57
    Tour991
    James
    South Reno/Tahoe
    I feel like at 2.5 you also will top out the uniball. Unless you have a limit strap. I think the manual hubs also add to the longevity of the boots.
  18. Feb 26, 2021 at 12:35 PM
    #58
    eon_blue
    Azusa, CA
    Oh yeah totally, because in 4wd offroad with the constant up/down on the suspension the boots are going to rub no matter what. It's the daily driving around town that does them in if they are rubbing at ride height. Manual hubs would be a big plus for that, that's for sure
    Tour991[QUOTED] likes this.
  19. Feb 26, 2021 at 12:35 PM
    #59
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Have you gone fast enough or jumped it enough to find the limits of your current (stock) suspension? i.e Have you overheated your stock shocks, or bottom out the suspension on a regular basis, etc...?
    If not, there's no reason to upgrade.
    You can also get a set of Bilstein 5100s and have a good improvement over stock as well, and spend 1/5th the amount of money.
  20. Feb 26, 2021 at 12:36 PM
    #60
    jbrandt
    Justin
    uh...
    unless they lied to me...
    I believe you can see the label.
