1 Hour Spring Clamps
Discussion in 'Suspension' started by 4WD, May 18, 2012.
  1. May 18, 2012 at 10:04 PM
    4WD
    4WD [OP] cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I don't know if this MOD has appeared here before , but no matter,
    after building a leaf pack or doing an AAL its always a good idea to add a little "sidewall" support.. Now most if not all clamps are done at the factory by way of drilling a hole & driving a huge ass rivett thru the clampbase & thru the spring/overload sometimes tension by way of a hole drilled thru top of clamp with a nut & bolt....
    These things seem to loosen up around the rivett in not much time allowing it to add to the other rattles & noises that drive us all batshit after awhile...
    So I came up with a cheap clamp MOD that so far seems to be holding up out there in the dez being mobbed by a couple guys I turned loose with them a few weeks back.
    Now I know this could be done alot cleaner, & alot prettier but that just ain't how we roll at OMD . (well, sometimes we're pretty:D)
    With a little 3/8" galvanized all-thread, a handful of nuts & washers, some 3/16" flat steel , we're going to help keep the leafs in place on the cheap...but cheap = shit if it doesn't work right ?....
  2. May 18, 2012 at 10:09 PM
    4WD
    Doug
    2004 DC TRD 4x
    The steel was cut at about 3.5" long pieces & I haven't measured the distance between the holes but I will in a bit....
  3. May 18, 2012 at 10:17 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    Curious if you use nylocks and leave them a hair loose or snug them up good and lock-washer 'em or??? I would probably nylock or threadlocker it. What sayest thou OMD? :D
  4. May 18, 2012 at 10:58 PM
    4WD
    Doug
    2004 DC TRD 4x
    I used 7/16" All Thread , which is a little over kill really, I'll use 3/8" for now on & save some $$$ (besides the ones that are being R&D'd are 3/8")....
  5. May 18, 2012 at 11:15 PM
    4WD
    Doug
    2004 DC TRD 4x
    Hey Thanks Brock !!....:wave::D
    Ya know I thought about nylocks & aircraft grade 8 anodized bolts too, but seeing how 16 nylocks would be needed (at about .30-.40 cents per nut, & I know for a fact that the bolts would be almost $2.00 each , just got some) & the whole on-the-cheap concept would be out the door...
  6. May 18, 2012 at 11:21 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    Understood! yeah those buggers are expensive... Love your spring refurb thread too. Hows your truck coming?
    Although I get my hardware at "Fastener's" they sell to all the big guys and are generally at LEAST half of lowes/home depot and like 75% off True Value. Just fyi ;)
    Aldog likes this.
  7. May 18, 2012 at 11:24 PM
    4WD
    Doug
    2004 DC TRD 4x
    So for as far as keeping tight its just flat washered both sides & if you lok in pic you'll notice a slight warping of the clamp ends over & around the spring, this is how tight you want to get these, no more, no less.. It's tight on the pack w/tension but not so tight that thread stretch occurrs & the whole mess loosens up....
  8. May 18, 2012 at 11:29 PM
    4WD
    Doug
    2004 DC TRD 4x
    Thanks dude..!! Almost have enough to get a rebuilt trans w/3 year warranty, damn I'm stoked, its been about 8 months without it on the road....:)
    & yeah, even better if you get material xheaper for sure...
  9. May 18, 2012 at 11:33 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Bad ass Doug!:thumbsup:
  10. May 18, 2012 at 11:56 PM
    4WD
    Doug
    2004 DC TRD 4x
    Hi Dave & thanks ...:)
  11. May 18, 2012 at 11:57 PM
    4WD
    Doug
    2004 DC TRD 4x
    Ok, that about sums it up, back in a bit with cost of MOD...
  12. May 18, 2012 at 11:59 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Nice that's a good idea so simple also
  13. May 19, 2012 at 12:11 AM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    what is the purpose of these clamps? to prevent the leafs from spreading from the centerbolt(pivot point)? is there anything preventing these clamps from sliding towards the axle?
    I'm just playing devil's advocate here...
    also, why not get correct sized bolts vs. cutting all threads(unless its cheaper for all threads)?
  14. May 19, 2012 at 12:19 AM
    4WD
    Doug
    2004 DC TRD 4x
    OK. this is how it breaks down...
    1 stick of flat 1 & 1/4"x 3/16"x36" - $7.98
    Zinc'd 7/16"x36" - $3.71
    around $7 or $8.00 for nuts & washers (theres alot of them)
    So you can figure under $25 for both sides..
    easy,cheap, & functional... I like it...:)
  15. May 19, 2012 at 12:24 AM
    4WD
    Doug
    2004 DC TRD 4x
    Hey like I said in the 1st post...
    :D:D You can go any way you want with it , I'm doing it hillbilly, cause at the end of the day thats what works (& being in Lakeside)
  16. May 19, 2012 at 12:34 AM
    4WD
    Doug
    2004 DC TRD 4x
    You could also leave enough allthread to double nut, its just the concept, it can be implemented alot of diff. ways ,thats the beauty...
  17. May 19, 2012 at 12:34 AM
    4WD
    Doug
    2004 DC TRD 4x
    I gotta ditch this sig pick, its freaking me out...
  18. May 19, 2012 at 12:37 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    TBD
    me too :eek: :eek:
  19. May 19, 2012 at 12:40 AM
    4WD
    Doug
    2004 DC TRD 4x
    fixed....:D
  20. May 19, 2012 at 6:00 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Doug,
    I wonder what spring dynamics would be affected were you to re-use the old U-bolts for the clamps. You would need to extend the threads and use only one steel plate to clamp on the bottom side? The rest of the hardware would come from the re-used U-bolts. Mounting the clamps close to the axle, there should not be much springing action there.
