1 inch add a leaf?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Jun 18, 2018.
  1. Jun 18, 2018 at 2:33 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Does an AAL exist that is only 1 inch? I tend to have some weight in the bed and it sags the rear end, plus a couple times i was on some trails like that. I just had the new leaf pack put on at Toypta and put 5100s in the rear so they allot for a 1 inch lift. Also, on top of increased weight ability, I'm hoping an added leaf may stiffen up the rear end a little after being softened up by the 5100s. Would this be the case?
  2. Jun 18, 2018 at 2:42 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I don’t think an AAL is going to be a solution longevity wise. If your leaf packs are worn out, an AAL is just a bandaid. I threw a 1.5” AAL on my rear end as a budget lift and it brought me up to 2” in the rear initially. I bet with some weight and putting some miles on it your oem leafs will sag back to usual and probably put you back around 1” of lift lol.
    Wheelers has a Heavy duty 5 leaf pack they sell that might net you the height you want along with the weight handling.
  3. Jun 18, 2018 at 2:47 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Toss the Toyota leaf pack in the dumpster. The leaf springs that come on this truck are garbage. The AAL will be a bandaid and ride like a dump truck. Ask me how I know. Got sick of mine after 3k and hauling a boat ONCE and they were flat.
    Get a new leaf pack. My dakars with the AAL for them rides 1000 times better than the stock Toyota leaf pack and a 2" AAL.
  4. Jun 18, 2018 at 2:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You could use a 1.5" single AAL and it would be fine with the 5100s, regardless of the fact it says it only works up to 1" lift. It doesn't ride like a dump truck like @geekhouse23 stated. I've had two different trucks now, and both with a 2" AAL which would be more stiff than the 1.5", and it still rode fine.
    That said, an aftermarket leaf pack is great if you can afford it, although it's understandable if you can't. $80 vs $500 is a big jump.
    shotgunbilly420 likes this.
  5. Jun 18, 2018 at 2:51 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I put brand new take off TSB springs and a single 2" AAL. It rides great.
    TAC1, outxider, lynyrd3 and 1 other person like this.
  6. Jun 18, 2018 at 4:06 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    This is more my situation. Though i have a champaign taste, I'm on a beer budget so the most economical solution is best atm. I wad considering putting on a rear sway bar to help with increased body sway from the 5100's but if an AAL will help the handling a bit as well as improving weight bearing, that may be my better route. And cheaper
    Alexely999 likes this.
  7. Jun 18, 2018 at 4:07 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Is there no such thing as a 1 inch AAL? Would 1.5 cause axle wrap? I didn't really want to dig into lifts because i don't want to stress any other parts of the suspension but 1" may be ok
  8. Jun 18, 2018 at 4:07 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would go with the AAL and go from there. I've installed 3-4 now, and IMO it's easier to just completely remove the leafs from the truck. Otherwise it's difficult to get enough space between the leafs and axle to get the new centering pin in. I've always gone with @Wheeler's Off-Road Inc and been very happy.
  9. Jun 18, 2018 at 4:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You won't notice any difference from that additional tiny bit. you'll be alright.
  10. Jun 18, 2018 at 4:20 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Would a 1-1.5" added leaf require new U bolts?
  11. Jun 18, 2018 at 4:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, not if you do the single AAL.
  12. Jun 18, 2018 at 5:13 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    What brands are recommended
  13. Jun 18, 2018 at 5:15 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    See my quote above. I would recommend wheelers offroad
    lynyrd3 likes this.
  14. Jun 18, 2018 at 5:20 PM
    lynyrd3
    Bill
    East Central Upstate NY
    1.5” should be fine . Add the Timbren SES bump stops if you are concerned with towing .
  15. Jun 18, 2018 at 5:34 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Why not just add Firestone ride rite air bags? Will improve load capabilities and stiffen the rear ride
  16. Jun 18, 2018 at 5:39 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I’ve had a pair of rough country AALs on my truck for about 2 years no complaints. Paired with some 3rd gen rear shocks.
  17. Jun 18, 2018 at 6:01 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Since this is the first truck I've owned it's my first foray into leaf springs. Are different brands of AAL of various stiffness?
  18. Jun 18, 2018 at 6:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Nope. They're pretty much all the same, rebranded hunk of metal
    lynyrd3 and Alexely999 like this.
  19. Jun 18, 2018 at 6:17 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    In my experience AAL's don't offer anything in regard to capacity. Not when they're paired with the shitty stock springs. At best they give you 1" of lift while unloaded, but once you start throwing the gear in they sag just as much.
    If you're serious about adding capacity, then you need a new leaf pack. Sorry.
    geekhouse23 likes this.
  20. Jun 18, 2018 at 6:17 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    +1 on Wheelers. Their progressive aal rides super smooth and not harsh like many single aals (you have to remove the overload for 1.5'' - otherwise you get 2'').
