1 inch body lift with 33s ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joshtaco08, Mar 10, 2017.
  1. Mar 10, 2017 at 7:35 AM
    joshtaco08
    joshtaco08 [OP] Active Member
    Josh
    Anyone ever try to do 1 inch body lift with 33s ?
  2. Mar 10, 2017 at 7:40 AM
    Pigpen
    Dan
    Northwest Montana
    I have a .5" body lift and 33s
    With a 2.5" suspension lift
  3. Mar 29, 2017 at 11:16 AM
    Inmand09
    Inmand09 ArkLaTex Offroad Vice President
    David
    Granbury, TX
    ‘18 White TRD Offroad
    3" Suspension Lift, Skids, Sliders, Ditch Lights, Rock Lights, CB, etc.
    No, but I was thinking about how this would work today.
  4. Mar 29, 2017 at 11:23 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Did you do a CMC still?
    RigginsTaco likes this.
  5. Mar 29, 2017 at 12:28 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Check out my build, Im running a 1.5" BL with 33's
    Going on 4 years now. Put it on shortly after I bought my baby brand new
    05tacomabro likes this.
  6. Mar 30, 2017 at 4:32 PM
    Pigpen
    Dan
    Northwest Montana
    I have 255 wide tires, so no need for CMC with stock rims.
  7. Mar 30, 2017 at 4:37 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    need for a cab mount chop wont change with body lift.
  8. Mar 30, 2017 at 5:05 PM
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    CMC is frame clearance, Body lift only lifts body. Frame and suspension remain in same position
  9. Mar 30, 2017 at 5:40 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    When doing a small body lift, what needs to be changed other than the bed/frame skirts?
  10. Mar 30, 2017 at 9:44 PM
    Pigpen
    Dan
    Northwest Montana
    I didn't change anything except the cab mounts
  11. Mar 31, 2017 at 10:11 AM
    WhiteNemesis
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    If you go with a 1" or bigger, be sure you either re mount the ABS wires higher, or you extend the wires before you install the lift. I tore mine, that how I discovered this. they are easy to unpin and extend. You could also leave them unmounted from the body.
    You also dont need bed frame skirts. I have gone 3 years with no skirts in my back end. Up front I ordered a roll of epdm, used a pizza box to made a stencil and made some new splash guards.
    Pigpen likes this.
