>1 inch lift = no 4x4 on 08 and 09?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by docuw, Mar 4, 2009.
  1. Mar 4, 2009 at 7:27 AM
    docuw
    docuw [OP] Active Member
    SLC, UT
    09 Tacoma DBL TRD Offroad
    3" Lift: Front - OME 885 Springs with N140S, Toytec 1/2" Spacer; Rear - TSB Leafs with Toytec TSB AAL and OME N182S. Total Chaos UCA's, Access Tonnaeu Cover, Dynolock Tailgate Lock, Polished Aluminum Bull Bar, Bed Mat.
    One of my coworkers has an 08 AC OR. He had a shock (bili) break already. He called Downey and asked about what he should upgrade to. They told him he can't do any type of lift on 08 or 09 Tacos because the 4 whhel drive will no longer work (due to splines not engaging). Is there any truth to this? I haven't heard of this elsewhere. He was told to get around this you have to put in manually locking hubs. The only thing I gave heard is that you shouldn't go >3" on the 09 due to the VSC. Does anyone have any knowledge on this issue?
  2. Mar 4, 2009 at 7:49 AM
    NicksRig
    NicksRig Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    I am pretty sure there are lifted O8 and 09's.
  3. Mar 4, 2009 at 7:50 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    He's an idiot. 4x4 works just fine. When you go up and past 3" (without a full drop bracket lift) you need to keep an eye on your CV angles on a 4wd, but that's it.
  4. Mar 4, 2009 at 8:23 AM
    Blu08Taco
    Blu08Taco Taco™
    Florida
    08 TRD Sport
    Sounds like he needs to find another shop lol
  5. Mar 4, 2009 at 8:55 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    definately not true....i've got about 3 1/4" in the front and 3" in the rear of my 09 and everything still works....vsc, 4x4, etc
  6. Mar 4, 2009 at 7:47 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Go to your dealer and have the bilstein replaced under warrantee.
    Decide on a lift later. Do some research on the Bilstein 5100's.
