1 inch rear blocks - pinion angle
Discussion in 'Suspension' started by double0taco, Jul 7, 2024.
  1. Jul 7, 2024 at 12:34 PM
    double0taco
    double0taco [OP] Member
    Dianne
    00 black tacoma pre runner 2.7 and 3.4 TRD
    hey all! due to the dumbass lift laws in maryland, i removed 3 inch rear blocks from my trd 1st gen and went down to 1, (which was well needed due to nosedive and them being 3 inch blocks lol) but the 1 inch blocks we swapped were bone flat not accounting for the change in pinion angle (front was 6 inch of lift and rear was taken from 8-6 from block removal) this caused tension on my rear carrier bearing which blew my rear diff. i need new 1 inch blocks that have the lower angle in the front (i believe it’s 1/4 smaller) or (2 degree angle blocks?)but can’t seem to find one with a detailed enough description/photos of the angle. please help
  2. Jul 7, 2024 at 12:50 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Try Amazon. You may have to get a 2 degree shim to add to the block if you can't find a 1" block with a 2 degree angle.
    Block will look something like below.
    double0taco[OP] likes this.
  3. Jul 7, 2024 at 12:54 PM
    double0taco
    Dianne
    i tried Amazon, rough country, and skyjacker maybe i’m crazy can only find one that says it in the description or photos, and it says a month to get to me.
  4. Jul 7, 2024 at 6:12 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You can also add a 2* to your leaf pack with a new center bolt and set on the flat 1” block. It will achieve the sam purpose. I personally don’t like the slip in shims as they give a little less center pin into the axle pad.
  5. Jul 7, 2024 at 6:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Will these work?
  6. Jul 7, 2024 at 6:39 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    A member here sells blocks with the angle built in, check with @mjbtaco to see what his lead time is.
    mjbtaco likes this.
  7. Jul 7, 2024 at 6:40 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  8. Nov 3, 2024 at 12:32 PM
    double0taco
    Dianne
    hey yall thanks so much for ur input! i ended up going with shims (i did not want to do this) i spent another week looking for blocks and was so distraught i just bought the shims and welded them to the blocks to add a little more security to my anxiety of them sliding out which is practically impossible now u less i lose my blocks completely. my pinion angle is set now and rear axel is holding perfect.
