1" lift in rear without using a block
Discussion in 'Suspension' started by Darty03, May 24, 2025.
  1. May 24, 2025 at 11:49 AM
    Darty03
    Darty03 [OP] •‿•
    2021 Tacoma TRD Off-Road V6 AT
    Has anyone figured out a way to get an inch of lift without using lift blocks on the 3rd gens?
    I thought about getting a progressive add a leaf pack and removing the small or middle leaf from the pack. I was worried it wouldn't get the results I was after or effect the spring rate to much doing that. With the over loads having to be removed I didn't want the spring rate to be so low I couldn't carry much load. I know deaver makes the J66 pack but from my experience with that pack and others I have seen online it struggles to even support a stock double cab.
    The truck is a daily driver, used to haul stuff and pull a trailer occasionally. It used to be offroad a lot but I got my K10 together enough and it's the trail rig now. The tacoma will still see some offroading just not as much. I'm doing the 6112/5160 combo and need to figure out the rear.
  2. May 25, 2025 at 9:49 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    1” block and Firestone Airbags for when you haul stuff.
    Darty03[OP] likes this.
  3. May 25, 2025 at 9:56 AM
    Darty03
    Darty03 [OP] •‿•
    I don't really need the airbags but it's looking like the block might be my only answer. I didn't want to add more axle wrap with a block but hopefully it wont be any worse with only 1"
  4. May 25, 2025 at 3:43 PM
    gotoman1969
    1” won’t make a difference at all.
    Darty03[QUOTED][OP] likes this.
  5. May 25, 2025 at 4:09 PM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    You get an AAL and keep weight in the box when you aren't hauling/towing. Will make it ride better as a bonus.
  6. May 25, 2025 at 4:24 PM
    Darty03
    Darty03 [OP] •‿•
    That thought crossed my mind but I didnt want to keep 100+lbs in the bed all the time lol. This truck isnt my "work" truck so it has minimal tools. I do have a hard fold up tonneau cover and bed mat but I doubt that causes any squat.
