1 mm as opposed to 0 mm Offset
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Harley2, Mar 25, 2015.
  1. Mar 26, 2015 at 2:34 PM
    #41
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I would suggest reading the following thread, and really educating yourself so you not only understand what this all means, but also how to determine what will work by being able to run your own calculations.
    http://www.tacomaworld.com/forum/wheels-tires/102992-wheel-backspacing-offset-info.html
  2. Mar 26, 2015 at 3:22 PM
    #42
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    you are correct that the stock wheeels are 16x7 with a 32mm offset, but you are incorrect, the backspace is 4.75".
  3. Mar 26, 2015 at 7:15 PM
    #43
    Harley2
    Harley2 [OP] Well-Known Member
    Rick
    Vermont
    15 Super White Double Cab 4x4
    Thanks! Appreciate the correction
  4. Mar 26, 2015 at 7:48 PM
    #44
    Harley2
    Rick
    Vermont
    Ok I'm starting to figure this out I think? So my existing wheel is
    16x7 32mm Offset 4.75 BS. New wheel is 16x8 10 MM offset so back space would be 4.39? If so the difference in back space would be .36 inches or 9.14mm. That's all great and I now know the wheel will fit as far as back space goes but how do I tell how much farther the wheel and tire will move towards the outside of the wheel well? I don't want the new rim to sit outside the wheel well. Is it simply 4" as opposed to the 3.5 stock wheel or an additional 1/2 less the .36? It will stick out an additional 0.14 inches?
  5. Mar 27, 2015 at 5:14 AM
    #45
    Harley2
    Rick
    Vermont
    Clear headed this morning and was able to finally grasp the concept. My new wheels with tires will stick out approximately 7/8" more than stock set up given the following. I added .75 inches to width for tires. :D
    Stock alloy: 16x7 +32mm offset 4.75 Back space.
    New Wheel: 16x8 +10mm offset 4.88 Back Space
  6. Mar 27, 2015 at 5:37 AM
    #46
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    OP pay attention, others are feeding you misinformation
    your wheels are 16x7 +30 offset (see this link for pics)
    http://www.ebay.com/itm/2013-TOYOTA...ck_Wheel_Packages&hash=item35e63187e6&vxp=mtr
    Use this calculator to visualize what the difference will be
    http://www.rimsntires.com/specspro.jsp
    Meaning:
    OEM: 16x7 +30 has 5.2" backspacing
    Desired wheel: 16x8 +10 has 4.9" backspacing
    Those specs are nothing aggressive... you'll be fine with a 265/70 mounted to them. You'd be fine with a 0 or even -6 in a 16x8 wheel
    #46
  7. Mar 27, 2015 at 5:53 AM
    #47
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    If you want it to be flush and look clean, get the 16x8. +0 with a 265 wide tire. Look at my build thread for more photos. The +10 will stick inside the fender still. The x8. +0 or +1 will be more flush.
  8. Mar 27, 2015 at 6:57 AM
    #48
    cyakker
    cyakker Well-Known Member
    SD (at least we're not Mars)
    2015 AC, TRD-OR, V6
    Quoted from post #42 (to reference the quoted quotes w/o looking them up).
    You're aware that the wheels with which you demonstrate measuring backspace in post #28 with are different than OPs wheels, yes? When you say "stock wheels", I think you're talking about your wheels and not OPs.
  9. Mar 27, 2015 at 8:20 AM
    #49
    Harley2
    Rick
    Vermont
    Thanks. Makes a difference. I'll be running the stock 245 75R 16 tire. looks like that will be a 1.3 or so inch difference to the outer fender well so it should not protrude outside the well. The reason I'm concerned is the same reason I don't run aggressive tread tires as much as I love the look, I live and travel on lots of nasty gravel roads and I have seen what aggressive tires picking up stones and flinging them onto the side of the truck will do...
    #49
  10. Mar 27, 2015 at 8:41 AM
    #50
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Look into the 16x8 wheels discount tire offer. They have a better selection compared to TireRack IMO
    Look at Method wheels specifically
  11. Mar 27, 2015 at 9:39 AM
    #51
    Harley2
    Rick
    Vermont
    I really like the Mongoose that Tire Rack has but I never say never! Lol.. Thanks for the help!
  12. Mar 27, 2015 at 10:09 AM
    #52
    rcsb jon
    Pittsburgh
    -WeatherTech liners
  13. Mar 27, 2015 at 7:42 PM
    #53
    Harley2
    Rick
    Vermont
  14. Mar 27, 2015 at 8:20 PM
    #54
    judgeman6970
    judgeman6970 Well-Known Member
    Bob
    Long Island, NY
    I think you'll be happy with 16x8's & +10mm offset...imo, good choice!
  15. Mar 28, 2015 at 5:00 AM
    #55
    Toeb
    Toeb Well-Known Member
    Toby
    Nc
    Trd off road
    Spc uca and leveling kit, 17" drop star 645 265/70/17, n fab step rails.
    im running a 17x9 with a -12 offset just have a level kit and lr upper controll arms no problems at all.
