1 or 2 gallon chemical sprayer for undercoating
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Oct 1, 2019.
  1. Dec 20, 2019 at 9:40 AM
    #41
    chaoselephant23
    chaoselephant23 Active Member
    Kristian
    SECT
    2015 Tacomer V6 AC TRD TOW
    Dual USB, Bed Store Locks, Remote Diff Breather
    One of the selling points of FF/WW for me was not having to wash the car during the winter months. I could go with my natural DGAF instinct when it comes to washing cars. As stuff will just sit on top of the FF/WW.
    I did a test run with my little 6-gallon Porter & Cable pancake compressor. Which did not work so well as I only got 5 seconds of spray, then a minute of compressor re-charge. Needless to say, I wanted to wash that first effort off before my official coating using a gas powered compressor rental. Coating did not come off when using low pressure rinse at the car wash bay. But did come off when using high pressure soap spray. But I had to have the wand 6" or closer to blast it off.
    cruiserguy and GQ7227[QUOTED] like this.
  2. Dec 20, 2019 at 11:13 AM
    #42
    GQ7227
    GQ7227 mw survivor
    J A Y
    so you are going to spray all over various body panel parts and never wash the truck?
    so far i can get 100psi air pointed right at this CF 3000 at close to 6" and it does not blow off, it just creeps and slithers around like a magnet, pretty cool stuff!
    i am waiting for some good slop build up to try it out at the wand wash
    black trucks look icky in the winter with salty grimy roadspray all over the panels
    this is the 1st winter attempting this sort of stuff so its a wait and see how it goes
  3. Dec 20, 2019 at 12:19 PM
    #43
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I spray FF all over the frame, bumpers, suspension parts, bolts and nuts, brackets, and basically everything that is not well painted metal. Then if I wash the truck in the winter I wash the body (from top and sides) and never bother putting a wand under the body. So all that winter crap I left alone to be stuck to the outside layer of FF.
    When the winter is over (or should I say in the middle of the summer on the hot day) I put hot water with soap on pressure washer and clean the crap out of the bottom of the truck washing off all mud, salt and year old fluid film. Then after all water dries out I lay the fresh layer of FF again. So far so good - three winters past and my California frame looks still like California frame :fingerscrossed:
  4. Dec 22, 2019 at 2:26 PM
    #44
    tony2018
    tony2018 Well-Known Member
    lay a thick coat,
  5. Jan 10, 2020 at 12:09 PM
    #45
    GQ7227
    GQ7227 mw survivor
    J A Y
