1 or 2 wheel drive?
Discussion in 'Technical Chat' started by Vege-Taco, May 22, 2008.
  1. Dec 30, 2010 at 6:29 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
  2. Dec 30, 2010 at 6:30 PM
    jandrews
    '09 FourDubDee TRD OR
    You're the confused one. Read the assumptions again. This is for single wheel loss of traction in 2gen Tacomas. Two locked axles on a 2nd gen taco - one wheel with loss of traction = 3 wheels driving the truck all with full torque.
    Other situations will obviously be different. Just trying to break is down fast n easy for the OP. If he really wants to decode everything, he needs to learn more about the systems themselves and problem solve on the fly himself.
    But I still <3 you. :p
  3. Dec 30, 2010 at 6:34 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Assumptions hmmm? The only assumption I read was jumping to the juicy part(the list) would suffice. I guess I made an ass out of myself. :pout:
  4. Dec 30, 2010 at 6:36 PM
    jandrews
    Synthetic?
  5. Dec 30, 2010 at 6:41 PM
    jandrews
    Fuck it. Just weld it front and rear.
  6. Dec 30, 2010 at 6:43 PM
    Jason'sLawnCare
    :woot: True 4wd donuts here I come
  7. Dec 30, 2010 at 6:46 PM
    jandrews
    Nah fool, to the frame :p
    That way you don't have to worry about the weak TRD OR rear end grenading...your axles will still stay on the truck!
  8. Dec 30, 2010 at 10:14 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    hit the middle diff while you guys are at it :D
  9. Dec 30, 2010 at 10:39 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It would be fun to be able to make a cartoon showing the four tires each over differing surfaces (ie. traction or no traction) and/ or on the ground and in the air.
    1) A 2WD open diff. would stop moving if one rear tire is in the air or in slush.
    2) A 2WD limited slip diff. would slow or stop briefly until torque transfered to the traction tire. It's forward movement would depend on road conditions.
    3) A 2WD locking diff. would continue rolling, unless the heavy front end was sunk into slush or sand.
    4) A 4WD with open diffs. would stop moving only if one rear AND one front tire is in the air or slush. Engine weight over the front drive tires helps achieve traction.
    5) A 4WD with limited slip (front and rear) would slow or stop briefly in slush as torque transfers to traction tires... it's ability to continue may be obstructed by steepness or traction since limited slip may not split torque equally giving enough power to the traction tires.
    6) A 4WD with a rear locker and open front diff. will almost always get through or up hills beyond open differential 4WD. Both rear tires rotate equally, at least one front tire rotates if it has less traction than the other.
    7) A 4WD with front and rear lockers or A-TRAC will have torque divided equally to each tire insuring forward progress... even if just one tire has traction and the other three are in slush or in the air (as in high centered).
  10. Dec 31, 2010 at 6:32 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Winner ^^^^^
    :D
  11. Dec 31, 2010 at 6:47 AM
    jandrews
    :rolleyes:
  12. Dec 31, 2010 at 6:53 AM
    BlueT
    NorthEast
    It is very funny post :D
  13. Dec 31, 2010 at 6:58 AM
    BlueT
    NorthEast
    Yeah but its not locking action..
    Try it... put your truck on 20 degree incline all iced up. Then try driving up.
    if it was true what you saying all 4 wheels would rotate at exact same speed just like lockers do. And we know already that they will not because system needs one tire rolling for measurement.
  14. Dec 31, 2010 at 8:16 AM
    jandrews
    I find it humorous mainly because most of the grenaded diff reports I've seen have involved misuse of the diff. I'm still not of the persuasion the e-locked rear is any weaker than the non-locked. Yes, it's a smaller diameter, but they could've easily used a stronger metal alloy to offset that.
    Until I talk to Toyota's engineers, I'm not making a call on that one.
  15. Dec 31, 2010 at 9:03 AM
    #35
    David K
    First off, I never said 'exact same speed'... the A-TRAC will brake a loose tire to match a traction tire's rotation, if different... This distributes torque to both tires per axle, instead of just the loose one.
    It is 'firmer' or 'stronger' at braking the tire than TRAC or limited slip does... and so provides the traction abilty of lockers... which ALSO match tire rotation across the axle... and yes lockers do so without any slippage or noise... but in the end, both vehicles get there.. and A-TRAC comes on our Off Road Tacomas at no extra cost... Front lockers do not.
    Now, as far as seeing the tires rotate at the same speed in low traction conditions... I guess you haven't looked at the video clips in my thread on A-TRAC?: This one is an FJ with fully inflated tires... never gets stuck.. but you can easily see true four wheel drive working with A-TRAC on:
    http://www.youtube.com/watch?v=_VHxslTiQug&feature=player_embedded
  16. Dec 31, 2010 at 11:04 AM
    #36
    drifter
    Sam
    Oregon
    good stuff
    been there, done that:eek:
  17. Dec 31, 2010 at 12:21 PM
    #37
    Jason'sLawnCare
  18. Dec 31, 2010 at 1:36 PM
    #38
    jeller317
    jeller317 New Member
    Jody
    Asheville, NC
    00 Tacoma SR5 V6
    I appreciate everybodys input. Since my truck is just a daily driver I think I just need a LSD for the rear. That should help get up my driveway in the snow and stop that annoying spinning of the right rear in the rain. The only thing I've seen online is made by Eaton. They mention one with carbon fiber clutches and I think I read something about another one run with gears (seems like there would still be some kind of clutches in there somewhere). The cf one was on ebay for $499. Is that the best deal?
    #38
  19. Dec 31, 2010 at 1:37 PM
    #39
    jandrews
  20. Dec 31, 2010 at 1:41 PM
    #40
    Jason'sLawnCare
    Auburn gear also makes some. I haven't heard much about that Eaton.
    #40
