1 piece driveshaft pros cons
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dYL0n, Jan 31, 2014.
  1. Mar 6, 2014 at 5:31 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    I have the same issue, barely noticeable if I pull away slowly but really bad if I step on it. Been looking into a new shaft as well. I had Tom Woods shafts on my Jeep and they were awesome quality.
  2. Apr 23, 2014 at 5:07 PM
    TacomaJay09
    TacomaJay09 Well-Known Member
    Central MA
    09 TRD Sport Dbl Cab
    None Yet
    Can you provide a link or info for where to get a driveline spacer? I was thinking about this since I changed my leaf springs and developed the driveline vibes. If the lift causes the driveshaft to be too short at the carrier bearing, could lengthening be the fix?
  3. Apr 24, 2014 at 8:27 AM
    SwampfoxSC
    SwampfoxSC Well-Known Member
    TRD SPORT
    +1 what skidoo man said. Those vibes will kill your seals faster than anything. I never had a double cardon. But the guys with fj80s raved about them. If you don't rock crawl. The clearance shouldn't be much of a problem for you. If you do get into rocks I would not do a one piece. Your pinion shaft bearings carries the weight of the shaft. I wouldn't see that being a big issue.
