1 Piece driveshaft vibrations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hennessy3300, Nov 4, 2020.
  1. Nov 4, 2020 at 1:04 PM
    hennessy3300
    hennessy3300 [OP] Well-Known Member
    I just installed a 1 piece Tom Woods double cardon driveshaft to try and eliminate my driveline vibrations. My truck vibrates worse now than it did with the 2 piece shaft. I've measured the pinion angle and I'm about 3 degrees off. Can just 3 degrees cause that much vibration? I've since then parked to truck (don't want to cause any driveline damage) and ordered a set of 3 degree shims. Has anyone else had this problem. My truck is a 2005 4x4 with 5100's w/ 2.5 springs and 2" aal in the rear.
  2. Nov 4, 2020 at 1:06 PM
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Take the shims off. I am running no shims and no vibrations at all with a 3-4 inch lift in the rear. The shims are probably causing your vibrations.
  3. Nov 4, 2020 at 1:07 PM
    hennessy3300
    I haven't installed the shims yet.
    Island Cruiser and 4wdExplorer like this.
  4. Nov 4, 2020 at 1:37 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I haven't heard of your issue before, but I don't tune into driveshaft issues much. Is it possible for you to stick a GoPro/camera under there while the vibes are happening? What speeds are you getting the vibes at?
  5. Nov 4, 2020 at 1:53 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    knowing only one side of the equation will not help.
    Your one piece, is it a double cardian joint at the tcase and a u joint at the pinion or two u joints? Whats the working angle of the joint at the tcase and whats the working angle at the rear?
  6. Nov 4, 2020 at 1:56 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    My guess (and only a guess) is that it’s not the driveshaft. How and when are you experiencing the vibes?
  7. Nov 4, 2020 at 1:57 PM
    hennessy3300
    Its a double cardon joint at the tcase and a single u joint at the pinion. there is a 3 degree difference from the driveshaft slope angle and the pinion angle.
  8. Nov 4, 2020 at 7:22 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Try the shims and go from there.
  9. Nov 4, 2020 at 8:41 PM
    nd4spdbh
    SoCal
    So if its double cardian at the tcase and a u joint at the pinion you will want essentially a 0 deg working angle a the pinion. Factor in some axle wrap and id say shoot for .5* of working angle for the rear pinion u joint (axle pointed just below the plane of the driveshaft)
  10. Nov 5, 2020 at 1:24 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Correct if 3 deg off add the 3 deg shims as double cardan (CV) pinion should be zero angle with the driveshaft per TW.
    But for others like me who have U-joints on both ends xfer and pinion angle are parallel.
    Article and pics at TW site article on
    Driveline Geometry 101:
    https://4xshaft.com/blogs/general-tech-info-articles/tail-shaft-conversion-kits
    Note: Also make sure if vibs continue that your trans mount is not separated/broken as its 15 years old. Videos on site on this.
    If you got a 4" shaft make sure clearance with the old center carrier bearing brackets so no hitting/scraping. I have a 3.5" shaft and clearance of 0.75" on each side.
  11. Nov 5, 2020 at 1:34 AM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Also look into doing the ECGS needle bearing replacement, I did it on my 1st gen and it completely eliminated my vibrations.
  12. Nov 11, 2020 at 8:46 AM
    hennessy3300
    Already did the ECGS bearing, made a world of difference.
  13. Nov 11, 2020 at 8:47 AM
    hennessy3300
