1 rod knock need help
Discussion in 'Technical Chat' started by tacocrazychris, Sep 8, 2011.
  1. Sep 8, 2011 at 3:13 PM
    tacocrazychris
    tacocrazychris [OP] Member
    chris
    winnipeg
    06trdsport_6speed~way blue
    Xm satelite,
    My 06 dc sounds like a diesle the more I drive it the louder it get but when I baby it not as loud I'm not a gearhead but to me it sounds like its gonna come right through the block how do I tell if its a rod or if it something else.
    140k kms
  2. Sep 9, 2011 at 7:36 AM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    What makes you think its a rod knock and not a main bearing?
  3. Sep 9, 2011 at 7:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    Spun rod bearings will sound like that. Drain the oil through a coffee filter and see if you have any metal shavings.
  4. Sep 10, 2011 at 12:21 PM
    Nolazach
    Nolazach Well-Known Member
    New Orleans
    An ARE camper shell, a 1000w power inverter.
    Ok, so If I have any kind of serious mechanical failure I should see some signs of wear in the form of shavings in my oil.
    I'm also having a noise, but I was using my stethoscope and it really sounds like a valve tapping. I really don't want to do a top overhaul. I'm just going to try an engine flush, and change and a tune-up. I'm going to try and pinpoint the problem now.
  5. Sep 10, 2011 at 2:32 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Do not use an engine flush. It causes more problems than it solves.
    A rod knock will be half the speed of Tacoma's normal ticking valve noise. Rod knock will sound more like a tock than a tick.
    If you find that you have, or think you have a rod knock, stop driving it. The stress of running it will grenade the engine turning a simple rebuild into a replacement.
  6. Sep 13, 2011 at 3:31 PM
    tacocrazychris
    chris
    winnipeg
    Xm satelite,
    Thanks guys big help after draing my oil and finding the shavings I came to the conculsion of a main bearing or rod bearing and my extended warrenty will take care of the rest.
    Who would thought buying an extended warranty would be a good thing
    Toyota couldn t figure it out but tacoma world did
  7. Sep 13, 2011 at 3:33 PM
    98tacoma27
    Ben
    Not Beech Creek
    That sucks man. Sounds like new engine time. Hopefully you can get this down with the least amount of hassle as possible
  8. Sep 13, 2011 at 3:40 PM
    tacocrazychris
    chris
    winnipeg
    Xm satelite,
    While there working on it should I replace all the bearings?
  9. Sep 13, 2011 at 5:01 PM
    98tacoma27
    Ben
    Not Beech Creek
    They're probably going to replace the motor
