1" Shackle?
Discussion in 'Suspension' started by tacoma02, Jan 24, 2011.
  1. Jan 24, 2011 at 2:35 PM
    tacoma02
    tacoma02 [OP] Well-Known Member
    2002 Toyota Tacoma 2.7L 4 Cylinder
    Thrush Welded Muffler Westin safari light bar
    I have looked at many threads on shackles and i know that any cheap way of lifting is the worst way but i just wanted your thoughts on doing just a 1" shackle lift in the back. Since its only an inch lift i was wondering if it would cause any problems in the future since my leaf pack is sagging a little. I was thinking on doing a new 5 leaf pack giving at least 1.5" lift but all i really want is an inch lift in the back so i just wanted your ideas, thanks
  2. Jan 24, 2011 at 3:43 PM
    tacoma02
    I also wanted to know if the rear 5100's give a little bit of lift, I heard that they give you about 1/2 lift in the rear is this true?
  3. Jan 24, 2011 at 3:52 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The 5100's in the rear DO NOT give you any lift. They are only a shock.
    Do some more research on lift shackles...but I'm pretty positive that in order go get 1" of lift using shackles, they need to be 2" longer than the original shackles. And to be honest....that'll unsafe.
  4. Jan 24, 2011 at 3:59 PM
    tacoma02
    yeah i do know that every 2" you get an inch of lift with the shackle but i just wanted to know if that extra 2'' shackle lenght would cause problems
  5. Jan 24, 2011 at 4:02 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    i don't know with problems your thinking of but none that I know of. I got AllPro shackles that only give 3/4" of lift so that might be something you might want to look at.
  6. Jan 24, 2011 at 4:14 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    we put some 1.5'' shackles on my dads truck to level it out after we put the aal in there and its fine. we pull trailers and such with it
  7. Jan 24, 2011 at 4:17 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    I have 1inch shackles on mine and I've had no problems at all. Ordered them from wheelers offroad
  8. Jan 24, 2011 at 7:32 PM
    tacoma02
    thanks for the info guys
  9. Jan 24, 2011 at 7:57 PM
    tacoma02
    the only problem i really heard of was longer shackles causing even more wear on the factory springs that are already kind of drooping do think a shackle 2 inches longer would do this or would i be safe as long as i dont go any longer?
  10. Jan 30, 2011 at 8:19 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    would a shackle lift give you better flex and keep the wheel on the ground longer when wheelin?
