1 Switch for Powering 2 30" LED Bars?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upTOPOverland_Drew, Mar 7, 2018.
  1. Mar 7, 2018 at 8:16 PM
    upTOPOverland_Drew
    upTOPOverland_Drew [OP] upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    Hey TW.
    I am getting ready to order some goodies with my tax return. I am dead set on putting two bars behind the grill utilizing SDHQ's light bar mount.
    This is the mount:
    http://store.sdhqoffroad.com/2016tacomabehind-the-grilledualledbarlightmount.aspx
    I am going to be using Cali Raised LED bars. On the bottom, I am using their 32" Dual Row Combo Beam. This bar has 60 LEDs drawing 300 watts. On the top, I am using their 32" Slim Single Row Bar. This bar has 30 LEDs drawing 150 watts. I will use the provided harness for both bars.
    My question is, if I use one OEM style switch from Cali Raised or something from CH4x4, could I wire both harnesses from each individual bar into one switch?
    My main motivator is so I can just put the switch in the OEM blank on the left side of the steering wheel for a cleaner install, faster operation and overall simplicity.
    Thanks!
  2. Mar 7, 2018 at 8:17 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    You'll need to use 2 relays, but you can trigger both of them from one switch.
  3. Mar 7, 2018 at 8:18 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Use a relay and proper gauge wiring and you’ll be fine.
    Lots of guys here connect multiple bars on the same circuits
  4. Mar 7, 2018 at 8:19 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    The harnesses have relays built in, does that count...I am wiring illiterate
  5. Mar 7, 2018 at 8:22 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Absolutely possible. Just run trigger wires from each relay to the switch.
  6. Mar 7, 2018 at 8:23 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    trigger wire? Sorry, I watched their install video and figured it would just be as easy as running each bar's harness in parallel and merging them at the switch. Is it not?
  7. Mar 7, 2018 at 8:31 PM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    That’s exactly what I’m saying. The trigger wires are the 12v lead that the relay diagram calls ‘switched power’. Power to that wire causes the relay gate to connect the power to the light.
  8. Mar 7, 2018 at 8:32 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Trigger wire is the white wire. Im assuming he is saying take both white wires from each harnest and connect to red 1 on the switch.
  9. Mar 7, 2018 at 8:33 PM
    Rooster OG
    Rooster OG Well-Known Member
    Tom
    Northern California
    Cement 2018 TRD Off Road M/T
    Yes, just join the switch wires from the relays to your switch in the cab.
  10. Mar 7, 2018 at 8:34 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    yes, this, and I won't burn my truck to the ground by doing this? :bananadead:
  11. Mar 7, 2018 at 8:36 PM
    Friedtacolover
    Travis
    Ontario, Ca
    More than likely :rofl:. then take the red 2 and connect to the cargo light green wire to light switch when dash is lit
  12. Mar 7, 2018 at 8:37 PM
    Rooster OG
    Tom
    Northern California
    No, you’re fine. If it does burn down we’re gonna need to see the video though.
    aaronarakaki and Friedtacolover like this.
  13. Mar 7, 2018 at 8:38 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    You guys are so good to me...but seriously, this should be a non-issue?
  14. Mar 7, 2018 at 8:41 PM
    Friedtacolover
    Travis
    Ontario, Ca
  15. Mar 7, 2018 at 8:43 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
  16. Mar 7, 2018 at 8:45 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    @CaliRaisedLed do both the 32" single row and 32" dual row use the same harness?
    CaliRaisedLed likes this.
  17. Mar 7, 2018 at 8:45 PM
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    hook both lights up with 1 harness each. do everything except install 1 switch. Plug either top or bottom harness into the 1 swtich. Jump/bridge A1 & A2 contacts on both relays. done
    Friedtacolover likes this.
  18. Mar 7, 2018 at 8:47 PM
    Friedtacolover
    Travis
    Ontario, Ca
    You will notice when you are done installing wiring your switch will have a left over wire. Wire red 2. Caliraised harness has 3 wires.
  19. Mar 7, 2018 at 8:47 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    I'm sorry J, english? Again, to everyone, I apologize for my ignorance but this not only confuses me but intimidates me
  20. Mar 7, 2018 at 8:48 PM
    upTOPOverland_Drew
    Drew
    Littleton, CO
    the connected the two reds from the switch to the blue from the harness
