1 ton brakes
Discussion in 'Solid Axle Suspension' started by superwhite, Feb 4, 2017.
  1. Feb 4, 2017 at 10:37 AM
    superwhite
    superwhite [OP] Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    Hey guys, I'm in the process of swapping in a dana 60. Looking to upgrade my master cylinder and delete the abs module. Does anybody have info on how to do the t100 mod or is anybody willing to make a setup for me?
    Thank you
    Sean
  2. Feb 6, 2017 at 3:06 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Bump. Does anybody know the t100 banjo bolt size and factory brake line fittings size? I'll be converting over to -3 an fittings and deleting all factory abs lines.
  3. Feb 6, 2017 at 9:17 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Try asking in the BS thread. Don't know myself.
  4. Feb 6, 2017 at 10:09 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    If by "t100 mod" you mean swapping the dual diaphragm booster and 1-1/16" MC out of a T100 into your truck, it's almost a direct bolt-on. You will need to modify the linkage to your brake pedal slightly, and possibly chop the threaded input rod into the booster so the clevis will line up with your new pedal linkage. The flared fittings should be the same as your stock lines, not sure exactly what they are.
  5. Feb 8, 2017 at 5:44 AM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    My next project is to upgrade the brakes. Still using the factory MC and booster :eek:
    My understanding is that the T100 is a direct replacement. That's what I am intending to do.
    There's also a chevy conversion. Low range sells a kit that has everything you need; and chevy parts are crazy cheap. But I have heard that the T100 swap is the way to go.
    James at Lowrange likes this.
  6. Feb 8, 2017 at 11:46 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    M10x1.0 inferted double flare
  7. Feb 8, 2017 at 7:28 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Thanks guys I got the tundra stuff ordered should be pretty simple as I have to replace my dash anyway.
  8. Feb 9, 2017 at 12:43 PM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    My T100 MC has the fittings on the opposite side of the MC. Not exactly a bolt on...unless I have the wrong MC
  9. Feb 9, 2017 at 4:39 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Not too sure, mine hasn't showed up yet but if it is opposite it's no big deal. I will be converting everything to an fittings and lines.
  10. Feb 9, 2017 at 8:39 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Maybe it is a straight swap on the 1st gens only? Dunno, but I remember reading somewhere here (maybe it was on Supra TT's SAS build) that it was direct replacement in his truck.
  11. Feb 10, 2017 at 11:44 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Just got mine and it is indeed opposite of the factory master.
  12. Feb 10, 2017 at 11:51 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Can somebody confirm whether or not is a direct swap for the first gens??
    @Supra TT
  13. Feb 11, 2017 at 4:05 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    it was a direct replacement for my truck. I used the 1 ton T100 as mentioned.
  14. Feb 11, 2017 at 5:07 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah it's a straight swap for 1st gens, I didn't realize that 2nd gens have the fittings on the MC towards the center of the truck.
  15. Feb 11, 2017 at 10:22 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Got the factory booster out tonight. Other than extending the rod to the pedal, looks to be pretty straight forward.
  16. Feb 12, 2017 at 5:10 AM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Cool, good to know then. This will be my next project.
    I assume I would need to get the corresponding/equivalent T100 parts (4cyl, 6cyl, etc.)??? Originally I was going with the chevy 1ton conversion, but then learned about the T100 parts and put things on hold until I figure it out.
  17. Feb 12, 2017 at 5:45 AM
    Supra TT
    Eric
    Indiana
    I don't know if the T100 "1ton" MC comes from the 4 cyl? I don't remember. But, there is a t100 MC "NON 1ton" so don't get confused. Idk if I have the part number in my build thread, but NwiTaco might, I used the same as him. He also makes adapter kits for 2nd gens to run the 1 ton T100 MC, it makes it EZPZ.
  18. Feb 12, 2017 at 7:07 AM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    Great, thanks for the info. I will look into it; but if you happen to know the part numbers please post them here!
    I might be confused about the 4cyl T100 thing. I may have heard somewhere that they had a 4cyl version that fell under the 1ton category. But that doesn't sound right...so never mind!
  19. Feb 13, 2017 at 5:06 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    Got the booster mocked up today, bolt hole centers are wider on the tundra booster (for 2nd gen) ended up hogging out the firewall holes and making a new plate that welds onto the footed all assembly. Also had to machine a new rod to go from the booster to my pedal assembly.
  20. Feb 13, 2017 at 5:13 PM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    @username might know of a brake upgrade, seems as tho I remember him talking about putting on some set that would throw your ass thru the windshield..
